Everything posted by raz
For anyone having iPhone I can recommend the free "Guzzi Tracker" app written by Paolo Rocca, a fan just like ourselves. It contains information, data and pics for virtually all Guzzi models all the way from the 1921 Normale. I hope it evolves and get updates for future models. Nice work! https://itunes.apple.com/se/app/guzzi-tracker/id1435726246?mt=8
- 1 reply
- 2
- specifications
- iphone
(and 1 more)
Tagged with:
I'm pretty sure you will find some replacement for that tube docc, just breathe through your nose and consult ebay
Made in China WTF!? Did they retroactively own your country?
Dammit that's (again) a brilliant description from Pete. He should be paid full time from Moto Guzzi just for existing.
I'm notorious for Excel-masturbating when weather or light isn't suitable for riding, it's a good thing others get some use of it
The WHB's do have a list on some page but it's incomplete - many settings are not included but scattered around at specific sections (which is good too but they should be in the list as well ) I collected all I could find when I had the 1100 Sport (all or nearly all will apply to V11 as well) plus some generics, see this page: https://www.abc.se/~rasmus/1100Sport-torque.html
Just cut off the peg that catches the spring, and it transforms into what you want. I didn't dare it without a switch though. https://www.v11lemans.com/forums/index.php?showtopic=13072
In the very short time I ran K&N pods, I could see a significantly worse air flow (up to 10% less fuel needed to reach same A/F) which should mean 10% less power. This is because the original filter box is tuned and the harmonics help the flow. I loved the sound and the looks though.
Very sad news. See you later, Slavo!
Here's a follow-up to that thread: http://www.v11lemans.com/forums/index.php?showtopic=15408&view=findpost&p=171867 raz
I actually have no idea, I haven't even checked valve lash since but I will soon. I am mostly concerned about the rockers because I fixed them by hand. If they look worse now I'll just replace them with new ones but they were not cheap. Why would a properly renewed one only last a year?
Tragically sad Moto GP. Marco RIP
raz replied to belfastguzzi's topic in Special place for banter and conversation
Just saw the sad news. I can't see how his helmet came off? -
Congratulations! I believe you should also visit http://www.centauro-...hpBB2/index.php - while the Centauro is a very different bike, it shares the V10 engine (and frame too btw). That forum is low volume but high quality.
As far as I know they are interchangable, the older one is paper and the newer is metal. The metal one is not reusable AT ALL. If you use that and, after properly torquing the timing chest, realise the little chain lying on your garage floor should have been in there, you need to get a new gasket. The paper one can probably be reused lots of times but personally I'd change it anyway (except for that chain incident) because it's a PITA to replace it.
Does the fuel pump prime for a second when you turn ignition on? The pump is on same fuse and same relay as the coils (and injectors). BTW check the fuses very carefully: I had a hairline crack in my ECU fuse, it REALLY looked OK but it was not. The giveaway was when I wiggled the fuse, the pump intermittently primed.
Metallic rattle? Full floating rotors?
I'd say it was time to change them!
raz replied to Keith Foster's topic in Special place for banter and conversation
Cut the tire in a cross section to show him what "thin ice" looks like..... Does his vehicle tires look like this ? Probably not............ That is a very good suggestion and actually I would love to see the picture here too, please? That would be very interesting! Both rear and front. -
Maybe some/all of those may be what you need. In my (1100 Sport) manual some specs are not in the table but scattered around the book in the drawings. When I can't find any other clue, I use the "standard value" for the size as Guzzi lists it. Side plate, rod beneath swinging arm 49 Nm (36 ft lbs) Side plate lowest/frame to gearbox 78 Nm (57 ft lbs) Engine to subframe, subframe to frame 78 Nm (57 ft lbs)
Germany is so loaded with camp sites we nearly always end up at some other site than what we were aiming at. Then again, we refuse to use GPS and we are equipped with teflon brains so no matter how much we try to memorise a route to a camping, we end up going in some other direction.
They last forever if greased now and then. Mine is like new after 80K kms.
Ah, yes. I assumed adding diodes that can take the full load. My point is there's no reason to hesitate to try external diodes as long as the internal ones are not shorted. I have a regulator that I'm sure has a bad (open) diode but it's intermittent so it looks fine when I measure it. If I ever need that regulator I will try external bridge rectifiers for sure.
Thanks! Are you talking of "thermal death" if a diode is added in parallel to a working one? When he said "only if they are open circuit" I think he meant it like "only if they are not shorted". Diodes often fail to shortcut, and then you can't add external ones. But this regulator is notorious for having the diodes fail to open circuit. AFAIK there is no problem with paralleling a healthy diode with another one. Right, Roy?
Set it at 8000 and you'll be fine. Mine is at 8500 at the moment because everything is 100% but I don't seem to need it. 8000 is OK and that was the OEM limit.
It seems most of the EU has gone to the peculiar point where this is more of an issue ON track than OFF it. It used to be the other way round, right? I have no problems passing the equiv of MOT with non-baffeled Mistrals but afaik there is no chance I can use them like that on a track day.
I could use some middle weight bike advice
raz replied to DeBenGuzzi's topic in Special place for banter and conversation
Wait, what was wrong with the ST2? Is that another thread? Seriously, I have really considered buying one so all Guzzi-head input is welcome. Not that I should trust you when it comes to buying bikes
