About Francis Chartier
- Birthday 12/13/1964
My bike(s)
V11Sport 99 / 1000 Strada 93
Francis Chartier's Achievements
Guzzisti (2/5)
0
Blowing Turn Signal Fuses,possible causes places to look?
Francis Chartier replied to mznyc's topic in Technical Topics
Same cause, same effect: front left indicator wire was pinched under left steering stop when bike was on stand, halft-cutting and shorting the two wires. As the wire were damaged in their protective insulation, It was not apparent without close inspection. Using tie-wrap to displace wires prevent this to happen again. -
I'll try to make some pictures this week-end (Guzzi informal meeting near Monpazier, France). The replacement part is composed of 3 different parts: two are custom designed to be fitted with an industrial part. Here are the tech drawing for the 2 CNC parts (with a thermal treatment) and some pics of the final parts and fitting in the bevel box. http://www.bete-des-vosges.org/V11s-2.0/Pont/ENTRETOISE%20INTERIEURE.pdf http://www.bete-des-vosges.org/V11s-2.0/Pont/ENTRETOISE%20EXTERIEURE.pdf http://www.bete-des-vosges.org/V11s-2.0/Pont/bagues.jpg http://www.bete-des-vosges.org/V11s-2.0/Pont/final1.jpg http://www.bete-des-vosges.org/V11s-2.0/Pont/final2.jpg http://www.bete-des-vosges.org/V11s-2.0/Pont/final3.jpg 2 or 3 years ago we made a few set, I could search for the industral part ref. No more problem of rusted needle bearing...
Same advice: I actually ride with 120/60-17 and 160/60-17 on my '99 V11 Sport (4,5" rear wheel). It feels better than the 120/70 + 170/60 that was the original fitting. I ride with Dunlop Roadsmart II and I find them far better than any previous tyres I use: Michelin Road Pilot/Macadam, BT 057/56/20/21/23..., Avon whatever, Pirelli Diablo...
Mods I have done on my '99 V11 Sport (short frame, 4,5" original rear wheel): - Forks: revalved Paioli UPSD + Ohlins linear springs, - Beringer cast iron brake disks, - Beringer CNC machined radial brake and clutch MC, - Ohlins rear shock with specific spring, - 1100 Sport triple clamp, - Rizoma handlebar, - Carbon fiber front mudguard, - Bevel box right outer needle bearing replaced by custom CNC machined part, - ECU replaced by Digital Ignition and PHM40 Dell'Orto with short action Tomaselli throttle, - K&N Pods with 2,5" pipes, - Moto Spezial Tacho and Rev clock, - Marshall fuel pressure gauge, - Roper Plate, - Complete QuatD exhaust: first version, non-cat free-flowing one. As I ride mainly on little twisty roads here in France (google maps: area Périgueux, Brive, Montauban: Périgord - Quercy area + Pyrénées) I choose to work primarily on suspensions and brakes. I am pleased with the result, bike is lighter than stock, more precise and quick steering without sacrificing stability: I ride without steering shock even on poor roads. As it is a '99 V11 Sport, I had the 2 rods replaced under warranty and made a nice deal on this occasion: I bring only the engine to the mechanic, giving him 3 month to do the job when it suits him without having to put the engine out of frame or back in. In exchange he wheighted conrods + pistons and balanced them with flywheel + cranksahft. I do not regret any mod done, bike is really fun to ride. Mod I dream to do: replace PHM40 with Keihin FCR and rebuit it completely using Ghezzi-brian frame and body.
Shift Return Spring Failure Poll
Francis Chartier replied to al_roethlisberger's topic in Technical Topics
65.000 km+ on the original spring from factory on my '99 V11 Sport. -
Suggestions on improving stock suspension.
Francis Chartier replied to Ritratto98's topic in Technical Topics
I have a 1999 V11 Sport and replaced the stock rear suspension with a reconditioned S46HR1C1S Ohlins with custom spring, bought from PFP (french representative for Ohlins). It get adjustable compression and rebound hydraulic damping as well as adjustable hydraulic sping preload (very convenient when alterning often one or two up fort short rides). I also replaced the dreadful 40mm Marzo fork with a 43mm Paioli SuperSport UPSD, bought new from the parts department of defunct Voxan factory (the Voxan Cafe-racer used that fork). Fully adjustable for compression and rebound hydraulic damping on each stem. I swap the original springs with stiffer Ohlins springs (1.05 ratio) as the Voxan was lighter that the V11S, with custom machined wheel axle and brake holding plates. These parts are far superior to the original ones, and the result is really effective and pleasant on the little and rought roads where I live (France, Périgord). -
I have a '99 V11Sport. I fit an Ohlins S46HR1C1S (retail part, not OEM part for Guzzi) with a spring choosed for my riding style and load, and found it far superior to the original Sachs. Same for the crappy Marzocchi 40 fork, replaced with a USD 41mm Paioli fork with Ohlins springs. Paioli Fork As the '99 Sport use the short frame, I change triple clamps for a 1100Sport model to gain a little more stability and I am very pleased with the results.
As he said. Two years ago I had to replace my '99 swelled tank by a '94 1100 Sport metal one, and let the streched one open and empty on a shelf. I saw last week that it shrinked enough to be used again without using a crowbar to fit. I'm pretty pleased to have more than 21L of gas, rather than the 17L of the 1100 Sport.
Some pics of the MC I'll try to do some more pics with the bike attached to the parts.
I use Beringer cast iron disks on my 1999 V11 Sport and Beringer Aerotec Radial MC for brakes and clutch with Brembo carbon-ceramic (organic) pads. Far superior to OEM Brembo in terms of efficiency and feeling. Beringer Web Site Braking is powerful, even using only 2 fingers.
My 1999 V11 Sport has a thread locker nut (metal type, not a Nylstop) and a washer. Probably a Luigism. :
EDIT: Even if the Calif is really a sedate beast I thought that an outfit was more prone to pickup exposure as it turns "flat": oil is moving in the sump much more than a solo. Aniway his engine got a problem of oil starvation (cam and followers pitting, rod bearings are shot) but it was in my opinion primarily caused by misuse and neglect from the previous owner. There was other signs: missing screws, rusted parts, overused brakes rotors, etc. The ongoing autopsy will tell if he'll do a complete engine swap or repairs, and he'll fit an oil pressure gauge to see if a plate is necessary. Thanks for the answer, I'll pass it to my friend.
Hello A mate who ride a Calif III/Watsonian outfit search an equivalent to the Famous Dr Roper Sloppage Plate. As it fits directly under the engine, the width&length are the same, but as the oil filter housing, pressure valve and oil pickup are in diffrent places I suppose the plate is different. Is ther any Sloppage Plate for Calif II? TIA
Moto Spezial in Germany sells several models of Instruments with Electronic Ignition http://www.moto-spezial.de/ Onlineshop, MotoSpezial Products, Instrument I have one (Doppel Instrument with Ignition) on my 1999 V11 Sport with Dell Orto PHM 41. It runs with the genuine Guzzi/Marelli phase sensor. I just had to reduce the gap under the sensor tip from 1.2 mm (as wrongly fitted at the factory) to 0.7 mm gap. Runs fine.
