jay904cc
Everything posted by jay904cc
  1. Did you just solder in a maxi fuse holder to existing wires or run all new? I was planning on running new 10 gauge wire from the regulator to the fuse back to batt. but if (after checking all other grounds, connections, etc) the existing wires are adequate I might do that.
  2. 2001 V11. Charge light came on, neutral light when out. On investigation the 30 amp fuse was completely melted in the fuse holder. Pulled it out and replaced. When running getting 13 volts but 30 amp fuse started smoking. It is getting so hot it melts the plastic. I will try to source a fuse box. Any thoughts on cause? Searching the forum came across the "Maxi" fuse thread. Will give that a try.
