v11cafe
About v11cafe
  • Birthday 08/10/1984
    California
1,046 profile views
v11cafe's Achievements
Guzzisti
Guzzisti (2/5)
0
  1. v11cafe
    v11cafe
  2. Enjoy the bike, few things might go wrong, might not, there is not a rule as quality was good in Aprilia years I can confirm speedo cable, pawl spring
  3. If I remember right diff between the ti kit and stock muff (cat version) was - ~8 kg crossover Stucchi with stock ~my hand says about the same Lithium pack batt versus my PC545 was -3.8 kg Rizzoma mirrors ~ -300gr
  4. Ehmm same happened to me about two years ago, alternator connector kind of melted. I got a new alternator and connector, no problems since then. I still cannot explain what happened though My (cheap) battery was low, I jump started the bike many times(I live on a hill lol) as I waited for an odyssey to arrive, and then as Craig describes.
  5. I tried a Leman clipon set to my cafe sport. Problem was 1/ brake lines were hitting the instruments, needs some conversion there 2/ Leman clipon have a screw which fixes the position on the top plate, cafe sport doesn't
  6. 1/Remove the tail plastic cover 2/Remove the original plate holder and the small subframe 3/Install the Cateye plate holder using the included parts 4/ Connect electric cables as shown in the picture.If in doubt or the cable colors of the light are different, using a multimeter in ohm scale check the continuity to find the earth cable (should be close to zero or zero depending on the accuracy and sensitivity of your devise).The other two cables would have bigger values. For the other two wires in volt meter scale, one would have always current as 2003+ models have no light switch, and the other would show a reading when you apply the brake as it is controlled by the brake switch. That's all.
  7. That is a part (made by rossopuro) bought from Stein dinse CATEYE-2 alu black Looks nice, good quality, but no installation or assembly instructions!!!
  8. Right!!!!
  9. It is not some big problem, mine does the same thing when hot. Maybe it loves winter When is fresh serviced phenomenon decreases.
  10. Sad RIP slavo drive ur twin up there
  11. Hey bud, hope I am stupid to believe facebook users and all is a sick joke If that is not a joke ....RIP guzzista (:-O
  12. I ordered a new one, still waiting. About two scales I am sure, my Cali does the same. Both have the pump in tank. thnx
  13. I remember that my fuel light(reserve) had two scales, soft glowing first and then full. Last three months it stays at the first scale which is hard to see in daylight. I know there is a sensor on the fuel pump, any info on that?
  14. Thank you very nice tour!
