BRENTTODD
Everything posted by BRENTTODD
  1. The guy at the bottom of the pic is bent over thinking about taking that rod but i dont think bore for a shaft like that
  2. Thats really funny i bet he will nearly fall off his soap box
  3. Dont be shy that isnt a lot of miles. The only reason you shouldnt buy that bike is if you dont have the cash for the little problems here or there. If money is not an issue jump all over that bike you wont be dissapointed. Good luck Brent
  4. Just like that
  5. Run the two front straps down to the frame mount that goes to the engine block there is a cross member to wrap it around. Make sure you start the wrap on the inside so the strap come out then goes staight back up to the clip that u can adjust. That is how mine is on. It works good when i wash my bike i release the clips and the bag slides side to side to clean underneath.
  6. Yea sounds like you have a air fuel ratio problem. You need to go back to the drawing board on that map and get your fuel trim in the right direction before you add any more goodies and worsen the problem Good luck and happy maping Brent
  7. Well stated I couldnt agree more
  8. I think I'll find and check that sensor you mentioned but mine does have a choke lever rather than any automatic jobbie so is it still the case that I might have to? Anyway, thanks again chaps. Still love my bike. Just want to know that all's well. That lever is for the enrichner it really isnt a coke even though it looks like one sound like one but it aint one
  9. Are you sure its running rich. You said you replaced air filter did you replace fuel filter at the same time? Im just thinking maybe fuel filter could be a little clogged restricting fuel flow causeing power loss. Just a guess if that dosent seem to be it change the muffler bearing they go bad all the time
  10. You guys have some kinda eye. I would have never noticed that master crafted hitech aluminum 1x3 from that picture. Good eye goodeye
  11. I bet it Brad Pitt gives her those massive titie twisters roughs those bad boys up
  12. sorry showed our hand again
  13. Yea they feed us some bad fried rice it made us crazy. I dont even remember anything from then on
  14. Tadletail Ive been a bad boy Hey Joe whats up with the windscreen is it guzzi or aftermarket
  15. I belive your guess will be correct. Buy a new set of valve cover gaskets remove valve cover to see your cracked gasket. Make sure you clean both surfaces very good before installing valve cover with new gasket. I'm not a tourk speck guy so rember tight is tight too tight is broke. Its really no big deal at all good luck Brent
  16. NICE She has the best DSL's ever
  17. I replaced mine last season and i followed the age old method of tight is tight too tight is broke.
  18. Pm Ryland he has a sorce for good relays
  19. As badmotogooser said i would start by checking all my gounds and work my way around from there Good luck Brent
  20. When will Jaap be back to save us? ROW NO ITS RODZILLA RUN RUN
  21. Dam they have everything but this years hot new nipple ring. I would have jumped on the wagon if i could get the hot new spring fashion nipple ring. I m the kinda guy that wants to be the first on the block to show that baby off. I guess Ill just have to go to walmart and pick that baby up.
  22. Remind me not to shake your hand you must have one hell of a grip
