STEELPULSE
    2000 V11 SPORT .... 2006 DUCATI SPORT 1000
STEELPULSE's Achievements
Rookie
Rookie (1/5)
0
  1. Hope you get a Guzzi and maybe we can ride the eastern shore roads sometimes as I often ride to Chestertown in the warmer months since I have family there.
  2. GuzziMoto do you mind giving a little more info on this shop in Harrisburg? sounds like a really cool destination. I love Porsches as well
  3. Hi Emerson900, I am in Columbia and if we can arrange a time you can surely ride mine around the block or something. I have a 2000 V11, the ergos have been modified a bit though, actually it is this months BOTM. I have since returned the pegs back to the standard ones so your legs should be pretty close to the lemans position.
  4. I pray that the lord grant Tom a full and timely recovery and for you and your family Van, God's blessings in times like this...
  5. I was not able to get a pix before taking it to my local dealer. but he crack is in the lower area between the drain plug on the left side and the bubble just above it in your photo.
  6. Well it looks like a bolt some how came loose from behind and fell into the outer none oil carrying section of the rear diff while riding causing the crack..:-(
  7. Thanks for the responses guys, I will post a picture when I get home tonite since I did not ride it to work today
  8. I hope I have the right name for it, checking tire pressure this morning and noticed a crack in the gray housing on the right side of my rear wheel. There is no oil leaking out from this though I see a drain plug on it. At the expense of sounding very uninformed, how common is this ? and what is the fix?. Thanks for your inputs
