First things first . after a couple of days edit your post that has the VIN in it and erase the VIN for your safety. The forks should have a compression adjust on one and a rebound on the other. IDK if you can install the same forks on these bikes or the internals have been swapped ?
My 03ish sport naked (I think) has white face gauges , the forks are different , the clip-ons are above the triple trees , The pork chops may be painted . IDK . I can't tell if your fuel tank has a chin pad or not. The white face gauges are supposed to be earlier than your bike's . My bike VIN is ZGUKRAKR6******** Also , IDK if my triple trees are drilled for bar mounts or not ?
Yeah , you have something extraordinary . google pics from M/G sales brochures for a lot less $$$ . Can you post the last 8 characters of the VIN ?
Can you post pics of the top of the forks , pork chops , clip-ons , etc. I assume yours has a black foam insert in front of the fuel cap to prove it is a external fuel pump .
What exactly are you trying to find out ? The front end can mean anything past the frame. Steering head , triple trees , forks , wheel , brakes , whatever . I know the forks on some bikes are the black Marzocchi and some use the gold Ohlins.
WHAT caused you to do something as absurd as to create a forum for something as laden w/foibles as this ?
I do know w/o this , I would not own my V11s and I certainly not appreciate them or have a relationship w/a task force of other addicts .
I bought mine w/a picture only. I can't remember how I found it . it came out of Fla. Did I want it? Absolutely . I had only seen one in person out at Gerald's shop. Did I think I would like it ? That was irrelevant .
Yeah , these bikes are HEAVY compared to other crotch rockets they are compared to and categorized with. 12k RPM , wheelies , stoppies and burnouts are off the list of things to do. A John Deere c/shaft & flywheel is not the hot setup for this bike.
The trouble is they are dressed up to look like a crotch rocket, The age of the average rider cannot reproduce the stunts Johnny Knoxville and his bunch do/did in his shows either .
Don't even think you can.
The Griso and the V85TT are some righteous bikes. Get your prescription filled ASAP . Disclaimer : this bike is meant to be ridden , worked on in equal amounts.
Have you been looking at a particular bike ?
IIRC , Montesa had a motocross bike and for a while they had "blooey pipes" . Think of expansion chambers and cut them in half at the largest diameter. i only saw them once in a DB or MXA magazine . I wonder how they sounded and if they did anything at all ? the equivalent to cutting off your exhaust system (on your car/truck about 24" off the manifold ? It's louder so it's better !
RR ?
Lagrasta , the temp gun was to check for heat buildup due to a poor connection. I have a couple of them and a FLIR camera to see any bad connections. If the connector is the problem , you can use crimp connectors to make a permanent connection and when the time comes you can cut them with side cutters.
Looking at the service manual : you should show 15v @ 1,000rpm . 40v @ 3,000 rpm and 80v @ 6,000 . I would not be stupid enough to tach it up to 6,000 in N so just stick w/the first two test #s. These are just for reference so don't condemn everything if it is w/in 20% of the V output of the test chart.
