It is unusual how so many members have similar bikes .
Well , they took the ugliest bike ever produced by MG and turned them into something pretty good looking !
IDK anything about these bikes . Are these hydraulic or cable operated clutches ?
I have been sorting metric/standard bolts/nuts/washers for about 6 weeks (to keep my sanity also) now and I am still sorting things out. I have tried keeping all the MG stuff together just wanting to keep them together. Those bolt thread sort tools have been a savior !
I hope you keep all your old fasteners that you remove from the bike and keep them in a safe place ?
FWIW , remove the spark plug and inspect it . it is probably damaged from the crash. Also, check the spark plug cap . Remove the (unscrew) cap from the wire and check the resistance ( I think it should be 5k) , and look for a tear in the boot.
Rosso Mandello color code for the gray parts
gstallons replied to Torstein's topic in Technical Topics
Just throwin' it out there for you -
The best color you can paint it is : hydrographics ! You can have it dipped in a CF coating and it will look RIGHTEOUS ! -
Nawww
MG Cycle has a socket (IDK if it is the correct socket or not) for sale on their site . $55ish .
Mmmm. I understand .
The only crummy experience I had was coming back from Anna, Il. at night and my l.h. valve cover gasket let go and had about 1 qt of oil on my left side soaking my BRAND new boots/brand new Levis by the time I got home . I didn't know that much oil could come out of a valve cover
And they probably feel like pantyhose !
I heard it was like Green Acres / Noah's Ark . I was moving stuff around and boxing up V11 , 1000 and V Strom stuff . When I was putting all the gaskets together I found stuff in these washing powder boxes torn apart and taped together to send my stuff to me. I couldn't bring myself to throw this stuff away. I could get rid of the contents first. When I first started dealing w/them , everything was sent w/a grocery store ticket showing the amount on the honor system .
That is FUNNY
Me too . When Joe & Ida Mae Eish stopped , I had to go somewhere else and MG seemed like the place to go .
What pats are you searching for ?
if there is NO metallic particles in the pan , you should be good to go . Leave the rods/rod bolts alone unless you install NEW bolts. I understand these capscrews are sensitive. When you go back together fill the filter w/oil just to CYA ! You are going to go back w/the Roper Plate addition ? I will have to check out the Valtec tensioner . Can you post a link to the timing chain tensioner ?
15.85mm= 5/8" . I am speaking as far as I can go on the subject w/o tearing something down . You will have to do this . IDK if there are casting #s on this anywhere or not ? This front braking system is expanding 8 pistons so I can see the need for a large bore to push more fluid .
I would think MG Cycle would have/offer all these parts. I would patronize them (personal preference) first and see what they stock . The fr. brake master cyl is a 12mm bore and the rear brake is a 15mm bore. I THINK all the calipers are 32mm fr. & rr..
On Harper's , go to brakes and the scroll down , they show front & rear kits but no caliper kits. Rear m/cyl. kit 17659350 for $39.44 and the front kit 17659352 is $29.95 .
All these brake parts on these bikes are Brembo. You should be able to find a Brembo dealer/vendor that can hook you up w/all the rebuild kits you will need to do this. I would do everything so you will be finished and not have any worries. I am not sure about the hydraulic clutch master/slave parts. Also, Ducati (along w/most Italian brands) use Brembo on their bikes, maybe you can get some help there. This is the first day, so maybe someone will come through w/a good lead. When you go back together use Raybestos brake assy. lube and ALWAYS use new DOT4 fluid. Brake fluid is extremely hygroscopic so always use new fluid. Purchase small bottles so you can dump the rest in your car , truck or whatever donor you have .
Which master cylinder are you referring to?
