gstallons
    92
  1. It seems as if the higher-ups are determine to hit an iceberg no matter how successful they have been . Intelligence rules over wisdom !
  2. I don't want to knock anyone out of a sale , but Auto Zone sells Odyssey . They just don't keep them on the shelf .
  3. AJ , buy a bike and then buy the green stuff. I have three fuel tanks for my 03 greenie . The original faded green , a champagne and a red tank . This only gets worse and these bikes will be the last things to go .
  4. I will never understand how stupid manufacturers can be . These guys will allow a Mom & Pop operation to close instead of working with them . All these idiots want a brand new store next to the interstate with $50k worth of apparel in the showroom and 12 employees selling you s**t you don't want .
  5. It's f'd up . Get a new one . You will probably have to remove the tank . If the clamps are indexed correctly , you can leave the tank on . If not , look at it long and hard to se how you can index the clamps so you can use a flex socket & a 7mm socket ( I think ) to get it the next time . I have a SnapOn flexsocket with the u-joint/socket together . $$$$$
  6. You know what a fuel pressure regulator is and what that nipple (usually) does . Well the V11 has it open to atmosphere .
  7. I like the "some" stuff . Please explain the rock and meter setup .
  8. That doesn't look good ?
  9. The best thing to do for an itch is to scratch it !
  10. Pop off the seals of the bearings and fill the cavity with wheel bearing grease and reinstall .Use anti-seize on the pins and nuts .
  11. The WIX 33463 filter has inlet and outlet on the same end with them pointing straight out .
  12. Uhhhh , 90% of the bike was made like this .
  13. A buddy of mine had one (Diana Mk IV) and let it along with 40 other incredible bikes go to Hell in a DAMP movie theatre .
  14. Just messin' with ya !
  15. Does that make you better or worse ?
  16. Franklin , that's where all the rich people live ?
  17. Swap the spark plugs from side to side & see what happens .
  18. Do you own / can borrow a temp gun or IR camera to check ex. pipe temperature after making a ride to see which side id hotter ? Inspect both spark plugs and diagnose them . As a natter of fact , replace the spark plug on the bad side to see what happens . I would hate to go through all this to find this out ! If the spark plug is good , then go to town diagnosing . I the bad side shows a lean condition , make sure everything is buttoned up around the throttle bodies , intake . etc . If all this is good , I would suspect the injectors . There should be an injector service in your area . They can verify or clean your injectors to match flow . Good luck !
  19. And she controls the hours of operation of the "amusement park" ...
  20. ALL tires are different . You can have the same tire size / different brand and model tire and have a monster difference .
  21. These cars are 10k more complicated / stupid and change every year to keep you out from under them .
  22. I hear ya brother . This old man said " this outer space technology is beyond me " .
  23. I don't need Halle Berry in a Catwoman suit , BUT ......
  24. You know how to fix that problem ?
  25. Remember , you are tightening a clamp , not holding an engine mount .
