gstallons
    92
  1. TC , what is it n how do you calibrate ?
  2. I know one thing , the first time I saw the MGS-01 I got an erection so hard a squirrel couldn't climb it .
  3. Beautiful !
  4. This is EXTREMELY important . What damaged spline{s) are you talking about ? I don't Know how to tell you ( I know but can't explain ) to index this coupling but it is critical , you can't be close . If it is incorrect the system will shake and go crazy . If it is out of index bad enough , it will damage the drivetrain .
  5. Hmmm . The case needed to have the sharp edges smoothed and the brace added . I don't think flogging the bike caused any of this damage .
  6. Mmmm. If you had a buyer's guide that would tell the application , you could have it looked up at a automotive parts store by application and go from there . NAPA , Standard Ign. , AC Delco , etc .
  7. There are places here in the U.S. that offer this cleaning and will test them to make sure they will match on a flow bench . Google ( for your area ) and see what you can find.
  8. That is the only thing I've seen Tridon in the US .
  9. rtfm ….. Hmm . I like it !
  10. Is that an Aussie brand ?
  11. Jaap , I truly envy you !
  12. I was giving advice to someone too easy to mess up with .
  13. Be sure you fill the gearbox before starting the bike . To be safe , add fluid through the glass sight plug after removing sight plug with a hex socket . You can flush the clutch cavity as much as you want . I would use at lest one can of Brake-Kleen spraying into the clutch housing . Hmmm . To be sure the installer adds the oil into the gearbox and NOWHERE else ?
  14. Isn't there a part # for an automotive o.p. switch ?
  15. Be sure you fill the gearbox before starting the bike . To be safe , add fluid through the glass sight plug after removing sight plug with a hex socket . You can flush the clutch cavity as much as you want . I would use at lest one can of Brake-Kleen spraying into the clutch housing .
  16. I'm not sure about the micron rating of a steel wool pad in a filter housing .
  17. Well , my favorite ! I will leave it at that .
  18. the 351C is the best engine FoMoCo ever produced !
  19. Oh , they are righteous , with a few problems . I had one on a 70 Mustang 351c 4spd . I had a 600 cfm double pumper with a chrome dual line I installed on it . I was George Thorogood in that car !
  20. That's the funniest thing I've read in a long X ! When that goes to Hell , you can remove the air cleaners . A Holley is guaranteed to backfire and start a fire . Burn the bike and collect the insurance !
  21. Make sure of the production date to make sure the tail section will fit the purchaser's bike .
