gstallons
    92
  1. What brand / model speakers ?
  2. Hmmmm . you sound like a septuagenarian ?
  3. Yeah N is good . I don't think you wanna post pics of your bike starting in gear . Or should I say , the results of your bike having started in gear .
  4. Disconnect and ground the N switch wire . It should start .
  5. 181 mi. ?
  6. Klu what ?
  7. Righteous !
  8. I really like that tank decal , where can l get them ?
  9. Hey , that is Diesel's old bike ! I bought his wheels/tires from him !
  10. How does this work in the rain ?
  11. Hmmm , how did it get apart ? I worked on mine with contact cleaner and working it about 15-30 mins.
  12. I just push buttons until I get what I am looking for .
  13. When I was younger and Ducati did that V-twin thing I thought that was the ugliest thing of all X …...
  14. It will be best to remember the difference and go on .
  15. If someone has screwed the adjuster where the clutch lever pushes the master cylinder piston too far , the clutch will not release after being pumped ?
  16. Beautiful , perfect photography , incredible ,
  17. No , my V-Strom is easy to drop ! I rode to this station up the road ( 2 weeks ago ) to gas up w/non ethanol . Came home , the kickstand retracted , we all went over . After 5 attempts including my pride I had to call a neighbor to pick it up for me . 3 chiro visits later I can walk O.K. now .
  18. IDK if the bike being discussed id a cable or hydraulic set-up . # 1 if it is cable operated you will want slack / clearance , whatever in the lever . Make this adjustment cold and recheck after the engine is normal operating temp . # 2 if it is hydraulic operated YOU BETTER KNOW WHAT YOU ARE DOING . If you "fiddle around" with the wrong stuff , you will create a hydraulic jack . Every time you pull the clutch lever the piston at the clutch release will be extended and not return . You pull the lever more and the piston extends more . This is the way a hydraulic jack works .The difference is there is a bleed screw that allows the pressure to bleed off at the small piston and the jack return to at rest position . If the factory set-up is set correctly , when you pull the lever , the master cylinder will operate the slave cylinder . When you release the master cylinder , the slave cylinder moves back to at rest position and the fluid goes back into the reservoir . If it is misadjusted , the fluid will not go past the piston and keep pressure in the system . This is why NO ONE should be messin' around with the stuff at the lever unless they understand what they are doing . The tech @ the Guzzi dealer , it doesn't sound like he was doing too good. Whew ! I hope I said what I meant ?
  19. Where did you buy the fuse holder ?
  20. In Ky they would have run over you and not stopped . Sad
  21. Schaeffer's stuff is great . We use all their stuff @ work . That place has been around for a million years and they are located in St Louis .
  22. I got mine a long X ago using MG parts . seals and bushings .
  23. That bike looks extremely clean !
  24. They are all part of the emission system . Leave them alone ( for now ) . I will figure them out and let you know how they work .
  25. You need to write a book .
