gstallons
    92
  1. Buddy , IDK but , that color is righteous !
  2. Every one of these bikes is …………………………..nevermind .
  3. Mine is an 03 . This is the EASIEST thing you will ever do . Call me . this will take 2 minutes . # 1 come up with a conventional ( regular size ) relay ,mounting bracket & connector. # 2 make sure there is NOT a diode in the relay . # 3 connect # 30 through a fuse to 12v , 85 to ground . # 4 disconnect the solenoid wire and install a wire with a male terminal to the existing solenoid wire , then to 86 .* # 5 go from 87 to the starter solenoid and attach using a female butt connector .* * use 16 ga wire to make sure you get optimum current flow to the solenoid . I mounted the relay to the battery mounting frame .
  4. Well , after 13 yrs. And a little work. # 1 Removing the fuel pressure regulator & cleaning it up/out . removing the fuel by turning the pump on & off 100 Xs and pumping out the stale fuel . Replaced qwith straight gas . # 2 Install new battery . # 3 cranked about 10 seconds pulling on the throttle cable . # 4 Are you ready to rrruuummmbbbllleee ? # 5 The sound of perfection ! # 6 the red frame is running .
  5. Look at the thread "What did you do to your Guzzi today" . I installed a larger automotive relay in series with the starter relay . Exactly what is the month/year of production of your bike and what model ? This is easy to wire into . Call my cell if you need too7oh ate4one one77for
  6. Oh no …….that is a VERY good price !
  7. The older you get , the heavier these caskets get . A man realizes how important your close friends and family members are , the day after they are gone . Brother , we feel for you
  8. Docc's the MAN
  9. What's the saying ? If it's too loud , you're too old .
  10. What year ? Red frame or black ?
  11. Why the smaller tire ?
  12. The red frame ( 2001 ) tire size is 160/60-ZR17 and the black frame ( 2003ish) tire size is 180/55-ZR17 .
  13. If you're looking for perfection , you're at the wrong place .
  14. What is the tire size on your wheel ? My red frame has the 4.5'' and the black frame has the 5.5" wheel . I will go outside and get the tire sizes and post
  15. You want a cognizant welder . One that is fully aware of what is going to be done . This is a process that is going to be done ONCE . disconnecting one post of the battery will keep all the welding trouble out of the electrical system . Always disconnect the negative post . I have never made sparks with a wrench on the negative post touching the frame !
  16. The cylinder head comes off very easy . Don't be afraid to take it off and do it right . If things get too f'd up .Time-Sert is the ultimate repair .
  17. What is that ? The Weather Channel reporting on this stuff off Florida ?
  18. This stuff is way too clean
  19. IF my order does not come through , I will contact you .
  20. NOOOOOOOO . ADHD is our main virtue !
  21. Hey buddy , do you still ride & own a M/G  ?
  22. Does the Norge have a helmet lock and or keyed seat release ? If so , you could remove one of them . Go to a locksmith and he could disassemble it and make a key to fit .
  23. Well , we are both from Ky !
  24. I would want absolute verification before I dropped that much on it . Lots of pics , dimensions , etc....
  25. Hmmm. The website indicates 94-99 1100 sport . I would contact them and see .
