gstallons
    92
  1. We both have the same hairstyle . If someone were to play me , I was thinking more Ernest T Bass .
  2. Hmmmmmm.
  3. I wish I were smart enough to make a video . It would have to be in subtitles to conceal the Beverly Hillbillies accent . Maybe dubbed by Patrick Stewart ?
  4. HMMMMM. look at it and think , if the u-joint cap failure allowed the cross to twist the yoke and cause it to break ?
  5. Is yours non-repairable ?
  6. Son Of A Biscuit Eater ….this thing is just a potentiometer ….. $ 200 ...wow
  7. S & S Cycles ?
  8. Over the last two days I scratched around and installed a relay at the end of the starter solenoid wire . I attached a larger automotive relay to the battery tray and ran my B+ from the battery through a fuse holder ( 20a) to the relay . Grounded the - to a 10mm bolt at the rear of the tank . The feed wire to the solenoid connection . The original solenoid wire energizes the new relay and the current goes through the larger relay . This will stop all relay problems and taxing the factory wiring and connections . I have done this a lot on equipment with Lucas starters that burn up neutral switches , solenoids , etc. P.S. I used 16 ga wire to go from the battery to relay and relay to solenoid .
  9. Maybe we can get together , My light will NOT come on ?
  10. I have been on this planet 63 years and last Friday ( for the 1st time ) I heard Peter Green's Fleetwood Mac . WOW ! Docc , post a video , you know I can't !
  11. I think every wiring harness is a prototype on these bikes .
  12. If it puts out 15v @ 1k & 40v @ 4k , i will trust the next # of output !
  13. What is an elephant foot adjuster ?
  14. I think you should be able to .
  15. Whew , I would run the LEDs in the rear and live with it .
  16. Did you look at the pins to see if they were burned or cut it apart to see if the contacts were burned ?
  17. What did you do w/the original stuff ? I need the screws that hold the lens to the housing ? Uhhh , the lenses too , if you have them !
  18. Did your operator's manual come with a diagram glued to the back inside cover page ? I took mine and had 3 normal size and one 1.5 size and laminated .
  19. If the previous owner has tinkered with it the clutch lever has a screw in the end of the lever ( or close ) that some mess with tring to improve or change clutch action . Send me you cell and I will send you a pic
  20. Your clutch slip , is it coming from the hydraulics building up from a misadjusted clutch .
  21. I bought the ones Diesel had on his bike . He had a crash n burn and I got them . This was a few years ago .
  22. Please explain yourself a little better . You adjusted which screw ? Changing levers would not require bleeding .
  23. Is this a question or a statement ?
