gstallons
    92
  1. How much will this be ? Post pics when you get it . You know these tanks expand/contract as much as your lungs ?
  2. Yep . You practice on a throttle plate from a junk carb and see what happens . You will be making marks all over the next one . Do these one at a time to not mix parts .
  3. Ya think ?
  4. Keyboard Carriage . They started hauling pianos . They move motorcycles too . You just tell them where the pick-up and delivery locations . they coordinate the moves so you have to be patient . You get better prices working with them this way . I met them when I picked up my bike . they were hauling some pricey bikes in their trailer .
  5. I've used Keyboard Carriage three times and they are fantastic !
  6. This is the same as knurling a piston skirt but , you are doing it inside out .
  7. What is the color of the wheel ?
  8. Please correct me . You did swap sides with the injectors ? Did this condition stay on the same cylinder ?
  9. You have it disassembled , when you get it together , start it up and use a mechanic's stethoscope and see if both injectors "click" the same ?
  10. If you have an IR camera or temp gun , run your bike down the road & back . Check temps at the exhaust pipes and see how close the temps are . I have temp guns and an IR camera .The camera is GREAT !
  11. If it will start , I would say the crank angle sensor is ok . I am going to say to test TPS sensor . If you don't know how , just acknowledge it & we will help you .
  12. Who handles Microblue bearings ?
  13. now that is thorough
  14. You need to be sure of what your problem is before riding this bike .
  15. To me that is 0.027" to 0.035 "....this to me seems pretty big air gap . Is this wide ? I would think 0.010' to 0.015" would be better ?
  16. # 1 remove anything that will give you a false clearance reading. # 2 make sure one tooth is in the exact center of the sensor bore . # 3 drop the new sensor into the bore and allow it to rest on top of the gear tooth . # 4 measure the clearance between sensor flange and mounting surface . # 4 add this # to the needed clearance and select the needed shim . Be liberal in adding the numbers . # 5 this should have you ready to go !
  17. 2 in my county . Mine and one red frame I can't get a title to .
  18. Define earlier / later please !
  19. It could be the shifter stuck on the pivot bolt . My bike stayed down for a month waiting on a spring on this account .
  20. I think I need to lose 40 lbs. more than I need to be installing new bolts.
  21. Can you post a pic of it ?
  22. gstallons
    Ducati in yellow . Welll I suppose !
  23. Ah , we're from the same time zone ! I don't think they would have used a round retainer .. a lot of Japanese bikes used to use a round retaining ring w/a 90 on the end so you could get them off . the best method is a snap ring w/eyes on each end . Anyone that has worked on one of these can chime in and clarify . BTW There is no way that ring can out of the cylinder .
  24. Did you paint it in place or pull it ?
  25. I will never forget the first time I heard a gear drive set-up in a engine …. Yeow . I thought George Thorogood was inside of that V-8 !
