gstallons
    92
  1. Hansson , the flywheel looks awful . It should be ( if at all possible ) replaced . This may not fix your noise but the teeth are in bad shape . When this is done you should use a dry film graphite spray or a good anti-seize lube on the splines on anything with splines . The clutch release bearing (as shown in parts diagram) is a Torrington bearing and appears to be where the sound is coming from . The part # is 12 08 70 01 in the 2002 V11 LeMans parts catalogue .
  2. What did you expect ?
  3. When this discussion reaches half time , what is the best relay to put in each position ?
  4. The one constant scraping sound that exists when the clutch is pulled in , is (in my opinion) the throwout bearing .The other sound(s) I am not sure of . I am sure you will have to disassemble the clutch to find the problems.
  5. You don't .
  6. Get it . PERIOD .
  7. We have the freedom of choice......
  8. Looks good . Get it !
  9. No....none at all !
  10. You can but , there is no "give" whatsoever with this type of setup .
  11. When you mount this link , these two mounting bolts need to be tightened with normal rider weight on the bike .
  12. The rubber in the bushings twists . The sleeve is to be clamped with the bolt into it's retainer .
  13. I mean real exaggerated angles . The minor adjustments we are making w/the (longer) shift arm extension and changes in rod length are not going to cause any harm.
  14. I was throwing this out for general knowledge or discussion . Linkages with same lever lengths should have the same relationship on their shafts. i.e. they should appear as a parallelogram from the side . You will get the same input / output from lever movement .
  15. Make sure you get a Roper Plate, two pan gaskets and hose clamp for the oil change.
  16. That is terrible and sad news. Sorry to hear .
  17. A long time ago , I used Channel Master Tuner Cleaner. I don't know what is the best product now ?
  18. And you don't know where we would be w/o you and your site .
  19. I am gonna have to look at my bike's linkage before I blab any more .
  20. I discussed this (lever, linkage efficiency) last year with this older mechanic about brake levers on drum brake mechanisms . He told me , the best brake effort is when the pulled brake lever is at 90 degrees when fully applied . I do not know how much is helped or hurt when shift linkage is lengthened / shortened ? 6 mm of length will make a BIG difference of lever position .
  21. Hmmm. I like the scale .
  22. I extended my shift linkage and modified my linkage rod as I mentioned in other posts. No problems .
  23. Yes. I suppose so
  24. They looked " aviation " quality .
