gstallons
    92
  1. Probably so . All bearings that are produced are metric . The 25x52x15 part # is also the bearing dimensions . I.D , O.D. & width . The 6205-2Rs should have those dimension.
  2. ! NZ dollar is $0.68 US dollar .
  3. That strong looking rubber mount is a pu$$y . Mine has been off for a long time.
  4. When you go for bearings....drop the 6 from the bearing prefix . It is a light duty version of the bearing. Instead of 6204 use 204 . Check them at your vendor to verify this,
  5. It has been 45 years ago this weekend that The Allman Brothers played @ Fillmore East and recorded probably the greatest live album of all time. I think it's time to put the CDs in and crank it up !
  6. I don't know how many are made of stainless steel . A lot of stainless is brittle and it will crack . The big drawback !
  7. These things need a 30a Maxi fuse / holder on this circuit .
  8. Best plate yet !
  9. You need to understand this "personal modification" will never stop........
  10. First , the rubber appears to be good. If it is o.k. then , take a flat file and file the surfaces flat on both sides of the inner portion and reinstall .Tighten the bolts to the correct torque and go !
  11. This site has many intelligent people and it is enjoyable to learn from them .
  12. It can't .....a resistance increase will not raise current so it would decrease the possibility of blowing a fuse.
  13. Are all buggies r.h. drive ?
  14. malengi , You should look to see if a washer is in a parts diagram illustration to see a part # .
  15. You would see if it was a dimple pushing out or an indentation actuating the switch . This will show you that it was mechanically operating the switch.
  16. Uhhhh. I followed his silver frame all day & I can say it's quicker than mine ( or me ) anyway .
  17. I don't know if their VIN sequence is meant to be understood ?
  18. Tilt the bike and remove the switch. You will see what the switch is actuated by.
  19. I had to remove mine & clean w/contact cleaner . Reinstalled & all is well. That was a couple of years ago....
  20. Sorta like the one you own ?
  21. Your search for delis will be replaced with searches for BBQ stands...
  22. Yes. an analog ( old timey with a needle ) meter is better to do this with. It will put a load on the circuit whereas a DVOM will not .
  23. Moto Guzzi owners are for the most part a professional in some form or another. they can carry on a conversation about some portion of their bike with intelligence and reverence and will work on / fixit themselves . No ''bulldozers" , they either know or will tell you they don't know . This is a good place to be. What I am saying....."Buy it " !
  24. Disconnect the connector from the neutral switch . Make sure the bike is in neutral . Put the bike in !st gear then shift up to neutral. Turn the key on. Ground the wire to see if the N light comes on. If it does , turn the key off . Take a good known test light and attach the alligator clip to B+ . Touch the probe to the metal protruding from the switch. If it lights the switch is good. If not , move the shift selector to see if it does ever light up. If these check o.k. , look at the wiring plug that pushes onto the switch . This may be enlarged and needs to be crimped just a little to get a better connection .
