gstallons
    93
  1. I don't think it works that way......
  2. You are not going to hurt anything by replacing the filter. Get a GOOD brand and replace it. Record the date & mileage .Keep up with ALL your services for you or the next owner .
  3. I found them . Do you need them ?
  4. I think I have some I bought off eBay... If you still need them post and I will try to find them .
  5. You say " no fuel is getting into the cylinder" ....how did you come to that conclusion ? Is there spark at the spark plug wire...is the fuel injector firing ....etc. ? If it is running on one cylinder , the fuel pressure is good .
  6. I think it has an aluminum washer that seals it , so just transfer it to the new sender .
  7. Well...can you give us some dimensions , head configuration , etc... ?
  8. Whai is the hex size and nut shaft size ? If it is 30mm hex and 19mm shaft size I have one . PM me your address .
  9. You mean the GB was your first two wheel experience ? What in the world inspired you to get it ? Those things never sold well and now they are sacred ?
  10. Whew....no good advice here . i am running Pirelli Diablo on mine.. Be sure to fill w/nitrogen .
  11. The Duc can become an off-road bike pretty quickly.......
  12. Duh.... AC as Alternating Current... LEDs will last a lifetime and be brighter too.
  13. It is supposed to be...I bought two..put them in the back of the bike and haven't broken one yet.
  14. Yes, they can leak ...start the bike and let it idle a while. shut it off and get the baby powder out and start applying it until you find the wet spot(s) .
  15. Good price... I welded a 3/8'' short extension to a 27mm nut to get mine out.
  16. For anyone in the States Google www.pure-gas.org and look for stations in your home state to find ethanol free gasoline . I use it in all my air cooled engines. Get ready to pay $$$ for it too !
  17. There are facilities that replace the nickasil coating in cylinders . You have to send the pistons w/the cylinders so they can hone to match the piston / wall clearance .
  18. Yes, it's a must in every shop. On the older tubes they said it comes from Rolls-Royce. Actually I don't know whether that's still the case, but in the 80ies it was. Hubert If I remember correctly it was developed for Rolls Royce for their engines .Still good stuff .
  19. Well , you could use Scotchbrite to hone the cylinder(s) moving up and down the cylinder bore quickly to get a cross hatch pattern and use brake cleaner to remove any foreign matter then lubricate the cylinder and pistons when reassembling .
  20. If it were me , I would pull the rods and have them checked. The procedure is not that difficult to do . While you are in there , new rod cap fasteners , ( price the bearings to see how expensive ) , keep the rod bearings indexed where they were when you tear it down. Spend the $$$ and get the Roper plate .
  21. Kiwi....chime in and interpret !
  22. Uhhhh , you ned to hook up a manual gauge to this before something expen$ive happens . Remove the sender and take it to a good auto parts store and buy a manual gauge with an adapter to fit your sender . Then reassemble it and start it up to see what hot idle pressure is .
  23. Unfortunately , these plugs should not look like this . I would think the oil is getting past either the intake valves or the piston rings . The least expensive step would have a competent shop to disassemble the heads and check the intake valve guides for too much wear . I do not think these bikes use a valve stem seal . You would have to check a parts manual. If this checks o.k. , then it is time to re-ring the bike . If you hone the cylinders , you can hone with a ball type hone for just a few seconds because these are a nickasil coated bore.
  24. If you loosen the banjo bolt at the clutch maste rcylinder , does the lever move any better ? This will test the clutch master / slave cylinder hose .
