gstallons
    82
  1. I could not pass that up! Good luck...
  2. Only a business owner would know this......... That's why you do not stock ANYTHING people cannot buy over the internet for les than you pay your distributors for the same product. Wait until they buy from you, order it in for less money, then bring that item back in and ask for a refund.
  3. Any husband with a knife wound.........
  4. David, I envy you living in such beautiful surroundings.
  5. A MotoGuzzi is both priceless and worthless at the same time. Go figure ? The ONLY way I would sell mine was if I found another one I wanted more....
  6. I just got a SHOEI from a Victory dealer (going out of business unfortuntely)in Cape Girardeau,Mo. and saved lot$ of money. It is more comfortable than the $90.00 helmets I am used to.
  7. You can remove the switch and stick something (be creative) into the hole to prevent fluid from leaking out. Then use a electrical contact cleaner to (obviously) clean the contacts in the switch. It might take a few minutes to do this so don't expect a sudden miracle. Use an ohm-meter to test the switch verifying that it now works and reinstall it. Check the gear oil level then you're done....
  8. When you reassemble anything using needle rollers, use a liberal amount of petroleum (Vaseline) jelly. This will hold everything in place til start-up. The Vaseline will melt upon warm-up and allow the gear oil to do it's job. Using any other type of grease MIGHT have a higher melting temp. This will give you trouble if a passage stops up and stops the flow of lubrication.
  9. Don't worry. they will break! I saw a man at the BMW Pickwick Dam Rallye who owns a Ducati. He told me his Duke let go of a timing belt.. $$$$$. He took it part himself and the head work was still expensive.
  10. I am sorry for the circumstances causing the sale. You know you will not be forgotten just because you no longer are sitting on one of the hardest seats in cycling. Please stay on the site and get another bike when things "pick up". Please (as with all members) keep us posted if you need any a$$i$tance. I have hit bottom before. After going through a divorce I lived in a friends house and then a church parsonage (free)because I was flat broke. Don't be afraid to ask, because I'm not afraid to give...........
  11. Looks pretty trick, what modifications have you done?
  12. This stuff reminds me of my AJS 250 Stormer I owned in the 70s. I found out that Lucifer and the British bike industry had an exclusive agreement on instruments of torture. I think British bikes should have a warning label "Don't ride me any farther than you can push me back" permanently attached to the top of the fuel tank. I was more than glad to give that #!!$%&^&(((*** $%%^&**&^%$$%$%$%%^^^ away.
  13. Your world has been forever changed...........
  14. I assume the color/texture match was perfect?
  15. Is that a factory wheel? I thought they were ony available with 16'' wheel or an optional 18" wheel.
  16. John, I don't think I posted anything disagreeable? Do you remember the brand and part # of the Mitsubishi starter. The relay is the only way to go to cure a lot of current (not voltage) problems. You will make sure you get a good flow of I and E to the starter solenoid. You will save the switch (from burning up) also. I nstalled a headlamp (headlight switch) relay kit on my 87 SE. This kept me from burning up a $175.00 switch.
  17. 16 or 18" front wheel?
  18. The most inexpensive tool you can own is a test light. When you have a "no start" condiriion touch the properly grounded test ligh to the start terminal of the starter to see if it lights when you press the starter button. If it lights the problem is the starter or improperly grounded starter. I install shakeproof washers on all ground connections. If there is no light,start going backwards on the circuit until you get a "light on" condition with the test light. I assume you have a wiring diagram and are competent enough to use it? If so,you will find your problem. If you need more help me pm me for my cell and shop #s.
  19. This crusty old man walks into the local Lutheran church one weekday morning and is greeted by the church secretary. "can I help you sir" ? "You sure as hell can, I want to join this Damn Church" the old man replies. "I"m sorry I must have misunderstood you,what did you just say"? Replied the secretary. " You heard me,I want to join this damn church" ! Shouted the old man. The secretary said "Sir I will be right back". The secretary went to get the pastor. As they were returning the pastor assured the secretary any language like that would not be tolerated. The pastor was very cordial to the old man and said" Sir, can I help you.What seems to be the problem"? The old man responded swearing and hollering "There is no damn problem. I just won $200 million in the lottery and I want to join this damn church and give some of my money to the church"! "I see" said the Pastor. "So is this bitch giving you a hard time" ?
  20. It looks like a roll pin. 1/8" diameter? You can purchase a double roll pin that is probably better.
  21. Gas n Go !! It looks ready to ride....
  22. I wonder if it would work for me?
  23. At least you filled it with something. You should hear about these Quick-lube places that would drain the gear oil on Saab 900s w/manual trans.,add 5 qts of oil and send them down the road!
