gstallons
    82
  1. gstallons
    Weight
    Just lock the bathroom door locked while you do this!
  2. I assume this has the same circuitry as a Jackal. If so the bulbs share a common ground, with the voltage regulator blue/white wire turning the bulb on/off. I'm too lazy to get up and look.
  3. gstallons
    Weight
    Have you got pictures?
  4. Check the charging output with a DVOM for at least 13v at 1500 rpm. If it's ok, ride it. my charging indicator light does everything wrong.
  5. What is a "loading" indicator ?
  6. Suspend the bike so the rear wheel is off the ground. Remove rear seat,fuel tank,air box, side panels,etc. to get to upper mount.Be careful removing the nitrogen cartridge. If you are scared place all fasteners with the component you remove. If you are not sure you can do it, pay someone you have confidence in to do this for you. It is a very uncomfortable feeling when you hear something fall off YOUR bike while riding. There are no extra parts on a bike!
  7. Do you realize how POOR the quality is coming from China?
  8. Welcome to the show I hope someone close to your location can help.
  9. China? WONDERFUL!!!!!!!
  10. That looks GOOD ! How did you do that?
  11. gstallons
    new owner...
    I hope you don't expect an unbiased opinon here on your decision making. Wait,on second thought, give me the V11 and I promise you liberal visitation rights.
  12. gstallons
    Finally!
    i think I got a cd from WildGuzzi that covers a bunch of bikes. It has parts catalogues on the cd also.
  13. I went and picked up my buddy's Jackal because he was stranded by a dead battery. After getting it off the trailer, I jumped it to get it I started it back w/cables attached and cheched for charging voltage= 12.11v not enough to be charging. Swapped batteries and started it again and still not charging. W/koeo there are NO idiot lights on. There is no high beam or flash-to-pass. I have checked all fuses and there is voltage on both sides of the fuses. I swapped all relays 2 at a time and still nothing. Can anyone help with a wiring diagram. The owner is out "tom catting" or I would get the owners manual w/diagram and lok myself.
  14. How does this tool help you push your motorcycle ?
  15. Is this paint or did you have the wheels anodized ?
  16. Fooey on the speed bleeder! Get some tygon tubing an a baby food jar 1/2 full of brake fluid. Bleed the fluid til you are satisfied it is clean and no air bubbles.
  17. I think Diesel has one? contact him.
  18. The standard clip-on is mounted on the top of the triple clamp. that is why you see the 25mm of the fork tub extending through the triple clamp.
  19. Would those jackasses (that recommended the flush only) let someone do that service to their bike after this repair ?
  20. Do you own and can you use a DVOM? if you answer yes to both you can test the tps. It is a potentiometer with 3 terminals. Supply v , V ref (signal return) and gnd. Two teminals wil read the same resistance at all times with the other changing resistance with the wiper movement. You are going to watch for erratic (fluctuation) readings with the wiper movement.
  21. This is VERY rude.... what does a 14 yr. old girl in Ky say when she wakes up in the morning? "Roll over daddy you're crushin' my cigarettes".
  22. And for the bucolic only.. What are the last four words you will hear from every redneck? "Hey y'all watch this!".
  23. I hate "blonde jokes" but this is funny. The blonde girl calls 911 to report that her house is on fire. Dispatch responds with the typical "how do we get there?". There is silence, then the blonde responds.."HELLOOOOO, THE F***ING RED TRUCK!
  24. That is why we wear ear plugs,full face helmets and muse of Steppenwolf,George Thorogood,Ted Nugent,BonJovi,etc...while we are going oblique to the Zeitgeist. p.s. you never waste when you learn and you are never a fool to your friends.
