I will have to look at the parts manual to see about this or this innovation ?
Do remove the shifter shaft bolt and make sure it is greased . Also install the shift extender to make it seem like the best Jap bike in existence. You want to get this running and then go "whole hog" on the refurbishing !
Is that "clear coat" on the tank ? Now , at my former place of employment , we were under the tutelage of a 24 yr old Anne Murray and this was her first job as a foreman . We were told what to use and how to do it. After The Beast of Belsen went back inside someone else said "this is what I've been doing" , so we did it the easy way.
BTW , remove the filler cap from the tank for a week before you do anything with it.
we were using those eraser things for a while. Just didn't work fast enough . Incredibly , we used heat guns to pull off decal/stickers from company trucks and construction equipment . when you get one corner loose , you could get it all off in one attempt. Now , this is a skilled effort so be careful . You will want to practice on something not so valuable !
Does Microblue recommend lifter lube when assembling the camshaft ? I do know the first 10 mins after start-up is the most critical !
The powerplant is different . Right from " how much throttle do I give this #$%^^&*((())!! to get it to start and then I hope this battery holds out long enough to start to I don't remember this thing making this noise before. Enjoying the SHORT throw shifter and forgiving the shut it off to find N now procedure. Being able to play with the throttle to keep from blowing the throttle bodies off when it starts popping . GRRRRR. With that being said , I will never want to part with one !
What model dash unit did you use and did you use a new or OE tach ?
Are you having performance problems w/your bike ? This bike appears to have one single throttle body w/an injector on each intake runner. one throttle body means no "balance" issues . Not as hot as individual throttle bodies but it is a trade off. If there is someone around that can "tune" your bike provided it is needed I would see about doing that.
A Moto Guzzi will never be a good investment PERIOD . A Moto Guzzi will be an extension of you . a. A Moto Guzzi will make me a better lover : NO b. A Moto Guzzi will give me clout w/my friends: NO H/Ds do that. c. A Moto Guzzi will make me a better mechanic , DC electrician , wiring diagram reader , understand mechanical theory and troubleshooter: It had better. , or you have wasted your time. d. YOU will become a part of a group of people you can contact 7-24 with a problem and get an ANSWER . e. Can I ever get my money back on these money pits ? NO
The seller knows what they have or they don't know what they have .... 9k is a pretty big #.
i don't know where all the members live concerning this Hurricane Helene / Tropical Storm / one helluva rain storm / bad weather. i hope / pray everyone w/ family & close friends in the pathway of this are safe and doing well. Please post about their conditions, etc. so we can be aware and hopefully relieved for them
I wouldn't exactly put it in the category "grocery getter" .
Do you have access to a parts manual to tell you what will or will not fit ?
It looks like they were trying to correct something . And it wasn't working.
Let me expand on this story. The previous owner had handlebars installed on the bike w/all the mods necessary to go from clip-ons to M-X bars . I must inform you , this guy was an "artist" and not a mechanic . It took s lot to remove his personalized ideas back to a normal bike. He must've had a hose shop do the extended brake hose because it looked neat . To go back to normal length , I had a buddy of mine make a proper length hose that would go back in place of the longer one from the brake m/cyl. to the tee at the front fender. If Walterg wants a longer hose , you will be better off having a shop make you a hose assy. where you can do this w/o any messy mods. There is a reason in a tee type hose assy. I just can't remember why? It has to do w/the hydraulic aspect of things. Plus it would look "not good" to have two hoses running to both wheels. REMEMBER to use D.O.T.4 fluid . If you use 3 you will experience brake fade when you try to keep up w/your Tn friends !
My red frame had the lengthened hose and it was an assembled hose with a tee at the front fender. I just went to the radiator shop that makes SS hose assys. and he made me a shortened hose . I went from bars to clip-ons .
You're welcome
If you can't stand the price of the LED filled fuses . Purchase Littlefuse , Bussman or a good known brand . There is an ATC and ATO style . ATC is Closed and ATO is Open to where you can probe w/a test light.
IDK what years the seat split but I don't think they all interchange ?
I didn't see the fuse . It was fractured , not blown . I saw this about 30 yrs ago on a F-150 w/no horn or turn signals or something ? Pulling it out of the holder and it looked good. Holding it up to the sunlight and you could see it broken off to one side . Good lessons are ones you NEVER forget !
What condition is the rear tire ? You might want to inspect them REAL good and install both .
