Dr. John Wittner estate auction
gstallons replied to docc's topic in Special place for banter and conversation
That is progress -
That is completely different . No rule was broken in that "design".
This may sound unfair . Anyone involved in the assembly of the powerplant , fuel system , whatever system that is not a legal component , the staff is banned for life . I think that might promote a NEW level of honesty . You don't mess with the factory , the rider or anyone else. Just replaceable employees. I don't think people are going to put their careers on the line for others .
I'm not gonna argue with you .
My experience with automotive sensors is to go OEM and stay away from franchise store sensors. You can get messed up fast. "But it can't be that , I just put a new one in there" !
Well , he's officially been flushed out !
That is how you make something into a Hot Topic !
I've seen gear drives , straight-cut gears ,etc. for car engines . They sound righteous . Gear driven camshafts are the norm on diesel engines , The stuff they are peddling for the M/G powerplant ? NO WAY . It is a waste of time to discourage someone from using it , they know it is what they want , let them run it and find out or "you must notta put it in there correctly" .
Didn't someone come up w/a crank sensor that goes in a Peugot or something like that ? These crankshaft sensors swelling and rupturing take place in the (domestic) automobile industry a lot ! GM had one in a FWD car that would fail , get stuck in the bore of the block . This would be so bad you would have to remove the oil pan and drive the sensor out of the engine block one segment at a time until you could install a new one. YUCK
ANSWERED Twentieth (XX!) South'n Spine Raid 2024
gstallons replied to Admin Jaap's topic in Meetings, Clubs & Events
What did you get ? -
Now I have seen it all!
gstallons replied to p6x's topic in Special place for banter and conversation
Hmmmm. I must not be mature enough...... -
I do like this
- 57 replies
Install the new front tire BEFORE you take a high speed spin around these country roads thinking your steering head bearings are stuck (it smoothed out from 50-90) only to get home and look at your Fred Flintstone front tire and realize the belt is gone ! -
Women can have high heels and men can have motorcycles .
You will enjoy being able to know something for sure and look at a wiring diagram and know if it's upside down or not !
The best use of the word philosophy was in Slingblade !
Now , I am not smart enuf to look up history on this forum . I did Google "testing the charging system on a Moto Guzzi V11 Lemans" and got lots of hits and the all referred to this forum . Most conversations go WAY back and are interesting for sure . Docc , Roy and others were already at the head of the class on this subject. Two critical points are 1 make sure you are using a GOOD and fully charged battery. 2 make sure you have a ground wire running from the regulator to a close bolt on the engine block. Use shakeproof washers on both sides of the terminal on a clean surface along with a non-melting grease .Do not go from the regulator to the battery neg. terminal . If the factory neg. wiring in the harness fails w/this in place you will have troubles and I mean TROUBLES . Remember , these charging systems are rinky-dink and just recharge the battery , they are not an electrical generating station . Treat them as such . If you are pretty smart on 12 DC ( I know an alternator puts out AC voltage) electrical systems read the post Phil posted above 3 or 4 times to appreciate all the info in the article. You will spend a good amount of time learnin' about what you need to know for in the future. Good Luck
Does this look right ?
I will go along w/the M/G Cycle gasket sans sealer . AFA the used gasket , hmmmm. When my starter went 3k rpm for 10 mins on two separate occasions , I looked at used ones on eBay and they were asking above retail ...... Yeow. It's not the fool that asks , it's the fool that gives.
It does look perfect . Be prepared to have fun ! I do hope you are some kind of professional . The knowledge will come in handy !
FYI , H-D dealerships operate in the black because of apparel . This salesman said "I can't sell everyone that comes through the door a bike , but they will buy clothing to show they have been here"!
I am thinking there is an improved timing cover gasket available too. Please use a good gasket sealant (Hylomar) when you button everything up and make sure you use a Roper tray on the bottom end . BTW , while you are waiting , start measuring the thickness of things . Anti-freeze jugs , Rubber-Maid products , etc. to get you a non-magnetic feeler gauge !
audiomick , do you have vernier calipers or access to this plasticene Phil talked about? You should be able to get it at Hobby Lobby or some place similar . And AMEN to a sealant upon final assy.
I'll have to think about it . Maybe somebody else will chime in 'til then .
