gstallons
    92
  1. gstallons
    Help
    Please let us know how it is going .
  2. gstallons
    Help
    You be absolutely , positively SURE this throttle plate is closed to verify a closed throttle. Fast idle linkage and throttle stop are OFF Most Cat stuff here uses Deutch terminals , is this an old jumper harness . BTW , using t-pins in the pcm harness is the thing until you can get a Casper kit . Both my bikes show around 550mV KOEO w/no fast idle cam applied. This is at idle throttle plate setting.
  3. Yeah , 15-18 v could make things exciting !
  4. gstallons
    Help
    IDK why I didn't think of this til now.... Remove the seat and use t-pins (or you can use sewing needles) to go down into the pcm harness (leave the harness connected to the pcm) at pin 1 and at pin 11 with them connected to the DVOM . W KOEO you can get your voltage reading there . This is what I did before I got my Casper harness.
  5. I would use a ring terminal and crimp it to the wire as good as possible and use screws to connect it to the CB instead of the push on terminals
  6. gstallons
    Help
    I am beginning to think these wiring harnesses are like ignition keys . They are exclusive to each bike .
  7. gstallons
    Help
    Looking at three different diagrams . 99 V11 Sport , my 02/03ish V11 Sport and a 04V11 Sport Catalytic . They are all different . Do you have your owner's manual w/a wiring diagram attached to the last page ? TJH , you have your old TPS , hook a DVOM up to the terminals on resistance scale Go from a to b and measure the value . Go from a to c and measure the value. The combination that gives you the least value is what you are you are looking for. Use pliers , screwdriver or something to turn the inside of the TPS to move it. Watch for resistance change. You are practicing for checking the mV reading on your bike . IDK how proficient you are w/a meter so I hope this goes well get a jumper harness and hook it up to your TPS and make the adjustments . You can stick T-pins in the wiring connectors and try to get an adjustment.
  8. gstallons
    Help
    According to one diagram A (violet) is v source and C (violet/black is signal return . Maybe red frames . Then another diagram shows A (violet) as v source and B (yellow) is signal return . Black frames ? And what is bad , I used this harness to adjust TPS on my red frame and black frame bikes. You practice on the TPS that is not on the bike and see what you get . BTW , is your bike a red or black frame ? The outer terminals on the connector are the ones I am using to test TPS v. A is violet , B is yellow and C is violet/black stripe. Good luck .
  9. gstallons
    Help
    I went o/s and found my leads , it is A to C you hook up to in order check the v on the TPS . BTW , go ahead and get the jumper harness. You want to get perfect readings on this adjustment.
  10. gstallons
    Help
    I have one and I soldered a pair of Fluke meter leads on to the correct terminals so you can attach the jumper harness and plug right into the DVOM and get a good reading .
  11. gstallons
    Help
    Plug your old TPS into the wiring harness and see what readings you get. Take a tool and rotate the inside of the TPS to dee if you get n increase in v when doing this . The TPS connector has 3 pins A B and C. C is signal return. A and B are voltage and gnd. Connecting a DVOM to C and either A or B will give you an increase or decrease in v when the throttle is applied. Make sure you are installing the TPS correctly when you put it into the top of the throttle body or it will NOT work correctly. I have a harness out in the shop and will have to see which way is correct.
  12. They change the price on the sticker
  13. That looks like the best thing and a good price too. I bought a Phoenix bleed system about 20 yrs. ago , used it four Xs . I would install those bleed screws and be happy with it. Also , you need to purchase bleed screw caps to keep out the bad stuff .
  14. That is the easiest and most effective method , just keep the reservoir full .
  15. UHHHH , the master cylinder is in the relaxed position . As in no one is pulling/pushing on any lever or pedal . Don't forget DOT 4 fluid only !
  16. A good machinist can make (including threads) almost anything
  17. I was making conversation to all that read this thread.
  18. The facts . The only pivot and jam nut I have is a (I measured) 20mm X 1.0 thread pitch . The outer hex is a 30mm head on the jam nut. Searching Fastenal website gives only 20x2.5 thread pitch only. You can Google and find plenty of offerings there . Not all taps/dies are created equal . Maybe someone will chime in on their favorite brand(s) of taps. The miracle of all miracles . I keep LOTS of things .a.k.a. JUNK in many plastic drawers . @ 3:45 a.m. I walked out into the shop , opened the first drawer and "presto" found the jam nut/pivot bolt . Remind Deanna to purchase Lottery ticket today !
  19. Did someone drop their bike ?
  20. These guys run the clutch covers like this so they will REALLY make a lot of noise !
  21. IDK if I can find a jam nut loose out in the shop but I will look and see if I can find and check the thread pitch . I am sure it is extra fine !
  22. I was just popping off. IDK if that jam nut is threaded all the way or not and I am too lazy to go o/s and look . Is this going on a red frame or black frame ? It matters.
  23. Sure , if you have a tap w/that thread pitch . Also the threads come to an abrupt stop. Just remove this jam nut and give it a look or take it to Fastenal and ask for help .
  24. The only thing I ever caught w/those things were a buzz !
