Do you have a link to the battery company ? how much ?
Thanks for finding that procedure Docc . I tried looking for it yesterday and ran out of time. I suppose the o-rings in the original manual shut-off valves had junky 0-rings and couldn't tolerate the alcohol content ? The only way to get quality o-rings is from a good industrial supplier .
Happy quarter of a century birthday to my MoGu Quota 1100 ES -
gstallons replied to p6x's topic in Older models
My speedo didn't have no 60mph swing ! No , when you get stopped , diplomacy means everything ! I've gotten out of some pretty big issues being nice . You can tell pretty quick how its' gonna go when the conversation starts ! now , I have watched a LOT of YouTube involving "sovereign citizens" . I can tell you right fast , if I were the law , one of us would spend 48 hrs in the hoosegow. I wouldn't put w/that feces one minute . And , congrats on you and your Quota ! -
One night I got stopped going into Tamms , Il. going 87 in a 35 . Some fast thinking mentioned "no dash lights" on the 87SE and I was forgiven . That bike loves going fast ! -
IF you have not located a manual petcock , I found a used one in my stuff. I was sure I had a new one. If you still need it , I can send it to you .
If you are competent , you can do it. Keep wires separated when you do the solder job and use silicone or something non-conductive to hold everything in place when you finish .
No problem . Find a manual petcock along w/any o-rings involved and get rid of the electric one.
ANSWERED Time to get the V11 out, but wont start...
gstallons replied to rich888's topic in Technical Topics
Yeah , I would swap that out for a mechanical one. When you install a new one you'll be delighted not to have to use a 18'' pipe wrench to loosen/tighten the shutoff . -
Anything is possible. Start eliminating causes. Answer Pressureangle's ?s first. Pay attention to the fuel pump noise when you turn the key on . Battery voltage= Fuel shut-off valve= do you have a mechanic's stethoscope ? If so , you might be able to hear it energize . That doesn't mean it opened . How difficult is it to disconnect the fuel line and see if fuel flows when you turn the key on ? I hope you are running ZERO alcohol fuel . this fuel w/alcohol content is not good on things Spark= have you removed the spark plug and reconnected the lead laying it over against the head and cranked to see spark ? -
In Ky there are all kinds of rules/limits on annual mileage / operating in parades , just a bunch of things to dissuade you from considering a vintage plate. -
Harper's has the best inventory but they mark the prices up above list price . I would try Google to see how many dealers there are in a 250 mile radius and go from there.
IF this shifter assy. is on the bike and is working condition, move the shift lever up and down and verify the foot lever and the lever inside the frame have no slack and this is tight . Morse = ? are you referring to the splines ? These 0-rings are nothing more than dust shields to keep out "bad stuff" and the wave washer or spring keeps the side (in & out) motion to a minimum . IDK how thick this frame tube is where the shift shaft goes through. I drilled / tapped the shift lever (not the frame) on the red frame for a grease fitting to keep the shift lever happy. You will have to see what you have to work with and decide if you can do this .
squiz= ?
When you have this back together , are you using the pinch bolt 10 to clamp the gearchange lever to the 12 shaft of the shift lever ? This is what holds these two components together and should keep them from sliding apart. Also , when you finish this project , you can drill / tap for a grease fitting on the bike frame where this lever pivots and be done w/any future problems.
Mine was a "mail order" bike. I knew I was gonna love it. I can't even remember how I located it ?
The clamp set-up Phil has looks pretty good . i use a conventional high pressure fuel injection hose clamp that covers the entire circumference of the hose and doesn't let the worm gear "threads" dig into the hose . Also buy a good (long) length of fuel injection hose. It will give pressure rating on the length of hose. Gates is the best , NAPA , then you need to be careful. Anyone else on brand recommendation ? This fuel line on the bike is approximately 20-25 yrs old . Remember this having the tank off. Also , when you have anything off under the tank , make sure nothing is going to touch , rub or damage ANYTHING else when you are going back together. Also , I use a small amount of Sil-Glide when assembling hoses to make them easy to go together and come apart. The two vents under the tank use a tee to make one hose to vent down & out of the way .
Pozidriv has been around for a LONG time . Phillips , Reed & Prince , Pozidriv , Tri-wing and JIS (Japanese Phillips) and maybe more are all modifications of the original Phillips head pattern. The Resistorx , I think is a tamperproof Torx. You see them around bathroom stalls . There is a pin in the center of the Torx "hole" . Oh , things change all the time . A few years ago Torx Plus came out . It looks like a stripped Torx bit. By now IDK if there is something newer or not ? Trust me , they will change something EVERY 5-10 years.
Your (emotion) expression will be the same as Jaap's
Griso is one of the most righteous bikes of all time
