gstallons
    93
  1. Remembering the past so you will not repeat it again . After my heart operation , my memory is about like Leanord in the movie Memento ! with that being said , I can remember my F-ups !
  2. That won't happen again
  3. The education is good , it's the tuition that eats you up !
  4. Unsprung weight savings , I'm all in ! What is all the goop on the drain plug ?
  5. Noooo. the omly way to fix this is with a new one. It seems like this seal and Deoxit are not compatible . I use Motorcraft electrical grease . It is available through Ford dealers . the compound is made by NYE lubricants . This stuff is for computer circuit boards , aircraft applications , etc. High tech and a fair price . I use dielectric grease in spark plug boots & that's about it.
  6. You gotts do what you gotta do !
  7. A vented system will keep the rear end at a constant ":pressure" and you will not have TROUBLE
  8. TE Connectivity 282087-1 AMP Superseal 3 Position Plug Housing | Waytek (waytekwire.com) Eureka ! And you will not break the bank with this price . I purchase a lot from this place . They sell quality parts .
  9. gstallons
    Purely cosmetic
    Yeah .......that is what we are not looking for.
  10. gstallons
    Purely cosmetic
    You do want to keep it conservative with changes . You don't want to end up with John Lennon's Rolls Royce. Little things will be noticed by the people that need to notice things . Sent from my moto z4 using Tapatalk
  11. My bike came w/the K&N setup. I didn't like the noise and reinstalled the factory airbox. You might replace the air filter once every 3 years so don't worry about it .
  12. That's the same place I ended up with.
  13. I think I have found a source for the TPS connector seals . www.customconnectorkits.com Look through til you see the AMP section. I hope this will work w/the price WAY less than $5.00 ea.
  14. OOOhhhh the rod , yeah it will just drop out , put it back in , you're good !
  15. Maybe you dropped piston only . can you reinstall ?
  16. Hmmmm. Explain . did you lose brake fluid too ?
  17. I used a 8mm hex socket & it broke loose w/no trouble. Use a good ratchet & cheater pipe if you need it .
  18. Oh yeah , what are the dates for this pow-wow ?
  19. Is this a form of extortion / kidnapping ? I don't remember us putting the finishing touches on your bike and comparing the Guzzidiag to a TPS reading ? BTW , the SnapOn scanner has a 4 channel scope too !
  20. Art , you are at the right place . Feel free to post as much as you want . Everyone is here to help .
  21. I looked through my box of connectors I gleaned from wiring harnesses through the years and found one Metri-pack that I think you can use the seal . If you want it , I can send it to you ?
  22. Not Weatherhead .....WeatherPack or Metri Pack ....neither style has the seal separately .
  23. It ain't good , whatever it is .
