gstallons
    82
  1. Mmmmmm . I want this
  2. The foil is GONE .
  3. I'm glad someone can post pics . These are just like mine
  4. If you are using the Casper's , your DVOM will show either a pos. or neg. V reading . I used terminals {meter lead ends) that I could plug my meter leads directly into .
  5. If you want to know what amperage this starter solenoid is drawing ; purchase a mechanical ammeter / amp gauge and wire it into the wiring terminal at the end of the harness that plugs onto the solenoid . Then go through the ammeter and back into the spade at the solenoid . Crank the engine and see what A it uses to operate the starter . It may go to max A in the beginning . Just see how much it takes to operate the starter . This will be the amperage required to operate the solenoid . Make your decisions then . I was too lazy to do all this .
  6. Well , it worked and didn't catch fire .... That's good enough for me !
  7. What work has been done in the past ? Go back to when you did not have trouble . You will figure out what is wrong .
  8. You do NOT want to ruin an engine , be deliberate and be careful
  9. They get heavier EVERY year .
  10. As long as I am alive , you will NOT be the the worst .....
  11. No , when you start drawing your own diagrams , you are getting better . Keep it up . You will only get better . Use the V11 diagram to compare with and judge your work with . Also , take your diagram to an office store , have it enlarged & laminated .
  12. There is no proper sequence for hydraulics . You just have to TRY what worked last time . Since there is no last time..... i have a (can't remember the name) hydraulic bleed kit and reverse bleed . Open the bleeder , connect hose and force fluid back through the slave up through the master and catch the fluid and air bubble(s) . You want the master to be as level as possible to get the air out . Also , you can push the fluid from the master through the slave to get the air out too . Keep the master as level as possible too . Good luck & use DOT 4 fluid
  13. Bridge , did you get the clutch working ?
  14. You can take the correct size wrench and loosen the nut by one flat and retighten the nut until it is SNUG . Or you can remove the tank and install a new o-ring and remove the tank 3 Xs , install a new low level sensor just to realize you could have done Step # 1 .
  15. The OTC 7103 set is probably the best to use .
  16. Uhhh , you have about $100 worth of picks and use caution & hope for the best ! Worst of all , make sure not to gouge the bore of the fork tube .
  17. look on Youtube . 3M AU-205 starting motor magnet adhesive . If I knew how to put it on here , I would .
  18. What does Google say ?
  19. Yeah , I think a person can think too much about something . I can remember having a conversation one time and this guy was concerned that the engine in his car didn't stop in the same position EVERY time .
  20. I bought some of these in the 70s from Fastenal & they were listed as spherical rod ends .
  21. Hmmm , I would talk to a starter rebuilder or (if there is) a starter forum and see what happens . Also , these things have to be in perfect position when reinstalling them .
  22. Stick a magnet up in there and remove all doubt .
  23. ALLMAN BROTHERS / Fillmore East . The entire recording . One of the best of all time .
  24. Buddy , I paid this shop $50 to swap the rear . I let them know "no mars , scratches , dings , nuthin' . I can't get another wheel like this" . Well , after a 10 day wait for a tire changer part , it is back ( in perfect condition ) and on ! One of you said "new tire , new brakes" was/is right . A law not a suggestion . Now , all I need is time .
