The OEM hose ain't suitable for anything , but it has the correct angles ! It is rubber (I think) only w/no cloth woven into it . This stuff deteriorates the moment it is removed from the plastic bag it comes in . i thught mine was in PERFECT shape until I went to look at how to R&R it to give advice to a member on this site . Yuck , it was junk .
Harper's : mmmmm. good luck . MG cycle : I use them since Joe Eish is NLA .
There is a "critically acclaimed" BBQ place in Murphysboro , Il. 17th St. BBQ. It's a good place to end up on a warm Saturday afternoon bike ride . Good place to go , but the BBQ is ok. Not the bst , but is good.
I never said I like it , I have seen it served at certain places ! I can't imagine anything green on my BBQ sandwich . It is a personal opinion .
Uh , we did stop @ Dos Copas in Madisonville Friday for a great meal for the 2 of us for $21 . It was terrific and the place was BUSY !
Survey time ; how many of you have had a BBQ sandwich served with cole slaw in (between the meat and the bun) the sandwich ? Some places around here serve it that way .
Sure thing . The red frame has green body parts , unpainted powertrain , forks , hubs , wheels , etc......
The black frame has (originally faded green tank) 3 different tanks , AWFUL black engine coating , black forks , hubs , wheels , etc.....
I worked on a Ford P-up for hours after pulling the fuse , holding it up to the light and it looked PERFECT . Pushed it back into the fuse panel and wasted the afternoon searching for the problem . Came back w/a test light to find out I had no power on the other side of the fuse . Installed a new fuse and problem was cured.
There are fuses w/LEDs to indicate a blown fuse . Get them ! They are lifesavers . Just remove the fuse cover and look for a light . When you are looking at a fuse panel w/30 fuses , it narrows things down fast .
My opinion of the purpose of these idle air bleed screws is ; to adjust the idle speed of the bike . You have set the base idle with the throttle plates/TPS .
You go through each step and do not go backward , but forward .
Watch all the other videos in that block also . It will help to understand Hall Effect v regular sensors . Regular inductive sensors peoduce a sine wave & Hall Effect produce a square wave. Don't trust everything you see on these . Such as 500 ohms being less than 2point 5 zero zero ohms !
