gstallons
    92
  1. A head guard and pipe wrap repair is small change to make it look perfect . ( If I were selling it )
  2. What you pay , is up to you . What it is worth is up to you .
  3. The 10th digit is the year of production . The first character is the country of origin . Z is Italy .
  4. Uhhh , yeah
  5. Take a hammer and put a ding in the rod about 1/4'' from the end of the rod and press it back into the bore of the cap .
  6. gstallons
    What year / model is it ? Looks pretty good !
  7. I think the best thing you can do , is get a Rosso Corsa tank . These are on eBay often , but IDK about shipping costs .
  8. PM your cell or do you have WhatsApp ? I will send you pics ?
  9. PM me your cell and I will send you pics in the morning .
  10. Another easy method , use a test light and test with it . put the test light from the neg battery bolt to ground at the starter housing . Try starting the bike . IF the test light glows , you have a poor circuit / start looking . same goes for the positive circuit . Go from the positive battery bolt to the positive terminal (stud) at the starter . If it glows , start looking . A good test light is as good as ALL my Fluke meters and a lot cheaper to replace !
  11. I have one , let me dig it out , inspect it & get w/you .
  12. Remove the switch and check continuity of the switch . Push the button/pin in and see what you get . One way should be open and one way closed . If not ,, try electrical cleaner and "pop" the plunger about 20 times and keep using electrical cleaner until it works .
  13. It is perfect looking . The last bid is around $2350 ?
  14. Brian , are you gonna leave us hangin' ? You don't have a blown up engine until you know you have a blown up engine .
  15. Well , I am glad I looked before I gave my worthless opinion . They do produce a contactless Hall effect sensor that can be used in place of a wiper/pot set-up . If you can get it in the correct range and configuration , your problems are over !
  16. I'm THE authority on ruining things . Get the Heli-Coil and practice on some junk til you feel confident in what you're doing . It's easy . If a Simpleton like myself can do it , you can too !
  17. Alright : drop the pan and check for metal in the pan and metal in the oil . Rotate the engine to where the rods are at the bottom of the crank and inspect the big ends of the rods ..... discoloration , stuff hanging out , loose on the c/shaft . Look up at the oil filter and see if it is loose or if the o-ring has spit out of the oil filter base . Report back .
  18. Relax , it will take a while before everyone sees this stuff .
  19. Parts cattle dog ? Hmmm. Yes , it was not fun swapping it out . You only do it once though !
  20. With the extender on my bikes , it shifts better than my V Strom and as good as a Jap crotch rocket ! It went from H Farmall to WOW !
  21. If I remember correctly , I had to remove the front wheel to swap . You will have to refer to an earlier post where I pulled a Cornwell toolbox drawer oxer the top and removed four coats of clear in the process !
  22. How about the two Allen heads at the lower left and bottom ?
  23. I have one on my 03 sport w/Marzocchi forks . i am sure there is a part # for each style of fork
  24. It is likely to be a MG product. IDK if there would be a emblem or part # on the fender ?
