gstallons
    82
  1. I hear ya brother . This old man said " this outer space technology is beyond me " .
  2. I don't need Halle Berry in a Catwoman suit , BUT ......
  3. You know how to fix that problem ?
  4. Remember , you are tightening a clamp , not holding an engine mount .
  5. TC , what is it n how do you calibrate ?
  6. I know one thing , the first time I saw the MGS-01 I got an erection so hard a squirrel couldn't climb it .
  7. Beautiful !
  8. This is EXTREMELY important . What damaged spline{s) are you talking about ? I don't Know how to tell you ( I know but can't explain ) to index this coupling but it is critical , you can't be close . If it is incorrect the system will shake and go crazy . If it is out of index bad enough , it will damage the drivetrain .
  9. Hmmm . The case needed to have the sharp edges smoothed and the brace added . I don't think flogging the bike caused any of this damage .
  10. Mmmm. If you had a buyer's guide that would tell the application , you could have it looked up at a automotive parts store by application and go from there . NAPA , Standard Ign. , AC Delco , etc .
  11. There are places here in the U.S. that offer this cleaning and will test them to make sure they will match on a flow bench . Google ( for your area ) and see what you can find.
  12. That is the only thing I've seen Tridon in the US .
  13. rtfm ….. Hmm . I like it !
  14. Is that an Aussie brand ?
  15. Jaap , I truly envy you !
  16. I was giving advice to someone too easy to mess up with .
  17. Be sure you fill the gearbox before starting the bike . To be safe , add fluid through the glass sight plug after removing sight plug with a hex socket . You can flush the clutch cavity as much as you want . I would use at lest one can of Brake-Kleen spraying into the clutch housing . Hmmm . To be sure the installer adds the oil into the gearbox and NOWHERE else ?
  18. Isn't there a part # for an automotive o.p. switch ?
  19. Be sure you fill the gearbox before starting the bike . To be safe , add fluid through the glass sight plug after removing sight plug with a hex socket . You can flush the clutch cavity as much as you want . I would use at lest one can of Brake-Kleen spraying into the clutch housing .
  20. I'm not sure about the micron rating of a steel wool pad in a filter housing .
  21. Well , my favorite ! I will leave it at that .
