Mmmmm. 2nd go round ?
Winter Project - My New to Me Sad Neglected LeMans
gstallons replied to Steve Swan's topic in 24/7 V11
Rule of thumb . Japanese rubber: eternal . All other rubber: not eternal . -
I'm not ready to go there yet. My thought is the rotor pilot veering right and climbing up into the passenger jet path . IDK if he knew the passenger jet had been diverted from Runway 1 to runway 33 ? I know ATC instructed him to go behind the passenger jet . It will all have to be pieced together . A LOT of small movements making one big problem .
Ahhhh , you got me there ! That was too obvious. Cow magnets , clothes pins and tin foil ? I thought that was just hillbilly tune-up stuff . -
Guzzi V11 Le Mans 2000...Starting issues
gstallons replied to David Sandbrook's topic in Technical Topics
see if anyone in the Osaka area can hook you up , or all of Japan , All (or most) Italian bikes use the same electrical components. Whatever you do , don't get hosed on the price of these parts. Surely there is a electrical geek that can test your VR and rotor or stator and verify what is good or bad ? -
If it had belonged to Steve McQueen , it is a good price . That is $760 USD . Is this price for the rotor , stator or EVERYTHING under the alt. cover ? Get on Euromotoelectric website and check their prices . You live in Japan(?) , is there no one there that works on European bikes/charging systems that can do something for you ? -
I have been on the Pilot Debrief portion since the rotor/fixed wing kaboom learning all these abbreviations and you spring a new one on me . Just what is a NAPA ff or a NAPA ff wrapped in tinfoil ? -
BTW , when you deal w/machinists , realize they have to know 10Xs more than the usual person before they can chuck anything up. When you do find one that will work w/you , you $how them your appreciation w/some good old filthy lucre and offer them help w/whatever your craft specialty is .
JW . Which part(s) are you needing ? BTW , don't go in the front door for things like you are asking . Go in the back door and be nice and see if someone can help you .
Make sure you index the hose clamps so you can tighten them and loosen them w/o much trouble . It will make it easier the next time. -
the first four points are good. The rear wheel bearings wear out from the wrong spacer because roller bearings cannot tolerate side loads . AFA greasing the front joint on a red frame still in the bike ? Post a Youtube video along w/the adapter .I wanna see it ! The battery ground to engine , you can use Caig De-oxit , Vaseline , grease or whatever you want along w/one or more shakeproof washers to verify a good ground . If this bike is gonna be down a little while , have someone make a larger diameter cable . These factory cables are Mickey Mouse as it is. -
Well , it involves fluorescent light bulbs string and some imagination . I got my two bikes tracking ( the rear wheel in the same track as the front) perfect after dismantling the swingarm . I will have to remember what I did and how . It sounds Rube Goldberg but after the epiphany it gets easy . -
For now back off the large nut one revolution , Remove the "bolt and leave the r.h. stuff on the r.h. side and the same for the left side. There is a procedure to get the rear wheel track in the center of the front. When you get it together , we will discuss it . -
IDK if this is a 24hr route past the Airport or IFR route only . Watching one of the videos it gives the altitude of each aircraft. I am sure the ATC rules here are different than anywhere else . There is 1600 Penn. Ave. to contend with along w/everything else there . I am staying open about this for now. I am sure Occam's Razr will "hopefully" decide , for now it looks like the chopper made a right and elevated 100' up into the airliner . BTW , I cannot imagine working in a Control Tower under any condition .
The "established route" follows the river as much as possible. It has been this way for some time. This was an understood route (like it or not) and had been used w/o troubles. From all the things I have seen , this chopper was to remain at/below 200' until it passed the Wilson Bridge (downstream of the airport) and then would ascend to 300' heading to Davidson AFB . Why this chopper pilot turned right and ascended I will never know . At some point prior to this there was a shift change in the Control Tower and the redirection from Runway 1 to Runway 33 was ordered . Also , the communications were where the ATC could communicate w/each aircraft but the aircraft could NOT communicate w/each other. When it is all said and done there were a lot of small infractions that led to this collision . Watch all of these videos shown to get (I'm sure you have) a better understanding .
That is why they are CEOs
I hate to see members that float away from the dock like so many members have. Can we incorporate a feature that "pings" them if they are not on here for 30 days or so to let them know they are missed ? We have had so many come n go. You miss them only after they are mentioned. -
Memory loss = what your friends tell you Too much to remember = what you tell your friends
There was once a little gem that few of us knows about: the TT650 Baja;
gstallons replied to p6x's topic in Older models
The FIRST ? -
Sherlock Holmes ! -
Whew......it looks like that thing was parked o/s and by a shed ! I will have a look and see where the - wire should be attached . I would think the owner installed a Ducati V/R . Don't worry about it. The magic marker stuff on the alternator , IKD. BTW leave the fuel tank open and it will return to normal . If it is hard to reinstall , you can pare down the rubber pucks at the front until they accept the tank . about 120 degrees of grinding is all you need .
