The Monkey
    5
Everything posted by The Monkey
  1. Sorry poorly worded Doesn't the alloy benefit from the expansion and contraction due to heating and cooling and the lubricant in that process play a part regards longevity or stasis of the material?
  2. We have to normalize or anneal hooks used for lifting. Ferrous material. this temperature treatment (controlled cooling) ensures the molecules are aligned for the task (proof load) does alloy not respond in like fashion? I was under the impression that the temperature fluctuation with the lubricant helped the material stay supple (relatively) am i mistaken?
  3. Glyptol was the go to for the cases on old American bikes. Now with the scarcity of correct parts from the 20s -50s this practice has revealed its shortcomings. Sealing against porosity locally makes more sense than overall as with time (30 yrs and on) the total sealing effect results in a dry aluminum or alloy that is difficult to work with being incredibly brittle. I'll throw this out here that any metal or combination of metals that can be fed (in our case oil aided with temperature change) should be fed. A parallel is ceramic material, Think of the old set of cracking ceramic dishes that were never used. Ceramics need water and temperature change regularly to resist brittleness and cracking, its the same with your motor (oil not water obviously). A local point where oil makes it through is worth rectifying but only for that point. Isn't it the rate of cooling that dictates the imperfections of alloys. it should not be a problem for the V11 as it is not a "busy" head. The 4 valve though (old and new) obviously should have had a better quality or smaller production supply to address the issue.
  4. The Monkey
    The Monkey
  5. I think you'd have to add 2 more cylinders to increase torque by 20%. Definitely remap the power commander. I lost 10% top end power and got easy 50% increase in fuel mileage when I did mine. The CDs are available, hook up a laptop and remap With my bike I suspect the original owner wanted to get as much as he could out of the machine. Also the shop had to produce a noticeable punch at the top end considering the cost of the Fast By Ferracci kit. The map I discovered on my 02 was not even designed for a V twin, it pulled hard to 220-225 km/h then rose smoothly up another 20 km/h. Fuel light would come on 150-170km I chose a far more conservative map and tuned the manual adjustments on the Power Commander until I had a favourable plug reading at 5500-6000 rpm Yes I lost the frenetic thrust at the final rpm range but gained big time on economy. As I was touring about on the V11 this made more sense. it could still dance 4th and 5th gear 150-180km/h and with patience would hit 230km/h indicated, but when ridden 120-140km/h the fuel light wouldn't show till over 280km Final tip for fuel economy- don't use top gear at highway speeds. Long legged and easy to live with means 4th gear at legal limit. Hey its Italian! I miss that bike
  6. Power There is nothing like experiencing that surge at high speed that only power can attain Economy What is that feeling when your low fuel light doesn't come on when expected or you get another 10-12% before shifting to reserve? Personality All 2 wheelers have a happy area where they shine. Are you happy in that machines moment?
  7. Great work gloves in that shot, unlined leather for less than 20$ Total respect Leave the wallet at home Save a ton
  8. How about one of those Triumph motors for a base under a glass coffee table?
  9. The Lemans fairing topped it off for me always loved Moto Guzzis approach to wind control I would only put an old SP Guzzi up to the V11 Comparison to anything but a V twin seems secondary as that is where a good bit of the appeal lies you can go a lot quicker for sure but does it tickle you the way it should These bikes were produced when everybody was into the V twin game. At 80 odd horsepower they just made more sense The Moto Guzzi is a peach, Ducati a plum. BMW compares as a fig -although I would probably grab an old toaster tank just to talk to the lesbians
  10. I do not ride behind Harleys, It mustn't happen. Certainly not on an Italian Stallion. I refuse to do it even when I ride a Harley. Its more fun to pass between them. Trail Braking is not unexpected..... the Spanish Inquisition was though
  11. Laverda parts: Columbia Car and Cycle Nakusp BC Go ride the Kootenays, you will be passed by one
  12. Riding fast is easier than explaining how to ride fast for most. Nick Ienatsch in his book Sport Riding Techniques does a very good job of transmitting the information you need. There are a few key things to understand and apply prior to practicing trail braking. This will benefit you when and if you do get out for the track day tutorial. Have fun, hopefully you have access to some corners.
  13. It influences the machine. Done right it creates a constant or settling and allows a faster entry. The point is to set the machine up for the next step (acceleration out of the corner) Practice it very gently using both brakes and then compare utilizing either brake. You will be amazed at your entry speed difference when you've acclimatized to it.
  14. That picture should be reposted with an invite to caption Docc Great shot
  15. The Monkey
    Zinc chromate
    Thats not a stainless bolt holding that cover on is it docc? Looking good though for a 100,000 mile motorcycle
  16. In high school during a lunch ride a close friend flew his 550 4 honda thru a wire fence. His mortified father snatched the keys from him and promptly bought a Grumman V tail aircraft. Had enough life left in the engine to attain instrument and commercial rating. We were 17, that poor Grumman was tough is all I can say. Loops, rolls, stalls, spins. Fuselage popping and squeaking I remember trying to stay oriented and looking over at him, calm almost bored, the land and skyscape a kaleidoscope. My guts were in my mouth. He still flys commercial to this day, won't touch a bike... far too dangerous. Wouldn't want to push ones luck now.
  17. Go to your local plastics shop and look at 1/8 and 3/16 material choices grab a 1/4 sheet. Make what you need Heat gun and a drill is all thats required
  18. It seems that where you buy your fuel (brand) decides whether or not you have issues. I have used ethanol since its introduction here in Canada. Mohawk and Husky both offer ethanol assisted fuels. I have had no trouble with the stuff for 9 yrs usage in the Guzzi. I still run it in the HD products (now there is an easily manipulated audience). No issue. Now is it because this cooperative adds the right stuff or is it related to how long your scooter sits idle? To me, if I cannot fill my tank with the watery rust coloured shite coming out of the available spigot wherever I may be, because my machinery is too fickle or my temperament can't deal with it then its time to adjust. I worked a tanker filling coastal fuel stations on this coast back in the 70s. Delivery was to 3 different brands-all major. Same barge, same line. 2 of those companies are still with us today, you may buy your fuel from them. You stop riding for more than 100 days, drain your tank and system. Understanding Fuel is a great topic, thank you docc
  19. full synthetic in the tranny, semi synthetic (SG rated) in the mill and origin with molybdenum in the bevel
  20. Yeah the merits of physio, chiropractic can't be overstated. Trick is find a good one. Nobody told me there'd be days like these When you are ticking hit the yoga or at least tai chi to keep things from seizing up
  21. Lots of runs through BC, Washington, Oregon, Idaho. Typically just short rides 2-4 days. Solid jamming though typical day 700-900 km, went over 1100 on a couple days but got kinda squirrelly. Ran down to the Siskiyous and Hwy 36 in California just to experience that road- well worth it. Stay off the 4 lane highways and interstates, 2 lane twisties only, craft beer and a tent.
  22. Thats the Le Goblin Mans Love child of the failed Davidson-Terblanche design team. Pierre and Willie did better on their own Jay Leno has one as it balances his chin
  23. In the spirit of screaming ladies and Italy You only get 1 which one would you choose? 1942 Alfa Romeo 6C 2500SS couple different coachwork companies supplied bodies 1924-27 Issota Frashini Tipo 8B There are many versions of this car, it even came as a Fire Truck
  24. 58 T Bird 352 Interceptor Drinks gas faster than i can drink rye (and I've challenged it)
  25. It might be Shiva Still would look better with a cigarette. Loopy girl still has my vote, tough enough to look good in such an oxidized state
