Wits
About Wits
  • Birthday 02/28/1961
  • Location
    Telford Shropshire
    1100 sport inj 1999 Loud!! Sold Now 1100 Breva
682 profile views
Wits's Achievements
Rookie
Rookie (1/5)
1
  1. Wits
    Wits
  2. http://www.gutsibits.co.uk/pr/TheShop/index.php?f=e&Shnew=1&Model=2&ModelName=Breva 1100, 1200 Sport, Norge, Griso, Stelvio&Cat=FUA&CatName=Fuel and Carburettors&spPage=2#topbar Part number FUA30000 Gutzbits in the Uk sell the plastic spigot/elbow Wits
  3. Please take care with compressed air, not to much pressure to start with..... I cleared the blocked vents on 1100 sport and breva with a mountain bike inner brake cable and a slowly rotatating battery dril. Working from the top and slowly introducing down into the vent. took a bit of time. Worked well for me
  4. Wits
    ECU Casing
    Cannot directly reply to the request fot ECU casing Thread. The early fiat Punto 1000cc ? (not sure of acutal cc) in europe used the same casing as the Guzzi ECU. Plenty around on ebay for not many UK Pounds Wits www.ebay.co.uk/itm/99-03-fiat-punto-ecu-kit-key-transponder-/271106596600?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1f365ef8 www.ebay.co.uk/itm/Fiat-Punto-MK1-1-2-ECU-Immobilizer-Key-/221155816709?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item337de9f505 www.ebay.co.uk/itm/fiat-punto-mk1-ecu-/170948286320?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27cd4fd770 all the above under £20.00 at time of writing post......
  5. Happy birthday
    Sold the 1100 sport now got a 1100 breva
    cheers JAmie
  6. Wits
    Wild Guzzi
    09-26-12: I have located the latest backup and am in the process of restoring the website to its entirety to a new host. Depending on the length of time it takes to do the migration, the current estimate is to be back online by 09-28-12. Thanks, Luap Just found this on website Cheers wits
  7. Don't be shy come along and show yourself, worth staying if you can, various outings on bikes also coach to and from Three tuns in bishops Castle sat evening Regards Wits
  8. Thanks for the info. I had heard that the BMW C1 headlamp was the same. There is one for sale on ebay right now, however it does not have the same part number. It is hard to discern the full text from the picture, but it is something like "tri.o.m 2080..." I have to agree with your assessment: is indeed utter crap! If I can't resolve this problem, I might just remove it completeley and get a daylight MOT! I would hardly notice the difference as I only use the bike during the summer months. How about running the whole caboodle through a bandsaw to get the lens off the pathetic black plastic silvered bit then moulding a new piece to fit with better adjustment? Just a thought... new LHD ones are over £100 - scary, but then it is from Built Minus Wit. The BMW C1 headlight is same as the Guzzi 1100 sport. The can be purchased from Motor works Homeforth part number 63122350525 £94.54p inc vat +carriage special order (2010 price) parts list http://realoem.com/bmw/showparts.do?model=0191&mospid=51722&btnr=63_0621&hg=63&fg=05&hl=2 also look at changing the wiring to head light look at http://ebbo.org/headlamp_relays.php. Made up this loom cost about £20.00 using good relays etc just need time to fit and test Mangaed to get a spare headlamp from e blag for £30:00p inc postage from germany cheers wits
  9. Hi Pavel Has the TPS been taken out of the throttle body by the guzzi shop? Could have been put back into the body incorrectly. As the voltage never drops below 5V. Never having taken the TPS out of my 1100 sport, that only solution I can think. Wits Shropshire UK
  10. Tim The inter-moto oil pressure switch, part number 50570 is the same switching pressure as the Guzzi one but has a spade type connector. Readily available in all good moto-factors (hopefully) wits
  11. There will be a meet on Monday 9th June 2008 from 1830 onwards at the Bradford Arm halfway between Telford and Cannock on the A5 (postcode ST19 9QT). The Bradford Arm is about equal distance between Birmingham, Stoke and Shrewsbury so lets put a few Guzzi's on the carpark. Food good as well!! Wits
