HaydnR
    1
Everything posted by HaydnR
  1. HaydnR
    HaydnR
  2. Did you not save the original map in case you need to revert to it ?
  3. I've had one apart and yes the wires were found broken. Just trying to remember how. I think i bought an aprillia rs50/125 switch from ebay as a spare. I will have a look in my photos. Pretty sure you jostle those tabs in somehow.
  4. I see the plastic fuel connectors have been replaced. Did they make a good job of it?
  5. A friend recently changed from single to twin late clutch on his tenni and had to modify the centre cup for it to work. Did you change yours or the pushrod?
  6. Guzzi V11 outside the U.S. only have spine frames, The rest of the world know the others as Californias and their derivatives
  7. Original engine the conrod cap fractured at 70mph. The sport corsa replacement engine has carillo rods so should be better.
  8. Horrible news. Ad posted on Gumtree and facebook uk stolen bike register.
  9. Shame about the lack of Guzzi
  10. Dunfermline Motorcycles knows what he is doing with them, he does them on mx bikes all the time. He had mine in at last MOT as it was leaking. There is also Bob Scott in Glenrothes he works on track race bikes a lot so should know his onions. I have not had any done by him personally.
  11. What is the fairing on that greenie, it looks good!
  12. Google search returned this http://www.v11lemans.com/forums/index.php?showtopic=12109
  13. HaydnR
    Nero search
    The black le mans advertised is a Nero Corsa, nice too.
  14. This wear is worrying. I think that the flywheel/hub is made of too soft a material (is it ergal?) The teeth on the plates should be made of a softer material as they are a damn sight cheaper to replace than a new hub and flywheel at every clutch change. The 1100 sport flywheel is slightly lighter I think, and looks as if it wears less.
  15. 'They all sound like that Sir' (twin plate dry clutch) , ride it and enjoy it. If in doubt stop next to a Ducati, if you can hear the clutch over the top of their ones go for a second opinion.
  16. Is this the same bike? http://www.gumtree.com/p/cars-vans-motorbikes/moto-guzzi-v11-sport/1024531082
  17. Workshop manual http://thisoldtractor.com/gtbender/mg_manuals/workshop_manual_v11_en_de_ne.pdf Wiring diagram http://www.thisoldtractor.com/guzzi007/schematics/1999_V11_sport.gif Parts manual online http://www.harpermoto.com/parts-by-motorcycle/2000-up-moto-guzzi-motorcycles/v-11-le-mans-sport-naked-1100-2001-2002.html parts pdf in french http://guzzitek.org/parts_list/gb/1100/V11Sport99_01_PL(F).pdf
  18. Welcome to the v11 fold. Pink fluid is redline shockproof. It is highly recommended although I have not used it myself. Check that the breather is clear on the top of the drive, as if this gets blocked the oil will push past the seals. Just take it out and try and blow through it. If really blockedyou can pry the cap off and clear it through with a piece of wire. Haywards near Cambridge have a pretty good reputation.
  19. Once you get the diagnostics running you wont need the tps harness, still handy though!
  20. Spot the difference? v11 electrical gu01747160 injection gu01725890 99-01 sport electrical gu01747130 injection gu01725830 01-02 lm naked electrical gu01747160 injection gu01725830 cat' 03 electrical gu01747191 injection gu01725875 cafe ballabio 03-05 electrical gu01747191 injection gu01725875 / gu01725891 v11 99-01 sport 01-02 lm naked cat' 03 cafe ballabio 03-05 images and part numbers from stein dinse online parts catalogue http://www.stein-dinse.biz/eliste/index.php
  21. I would go with the blue one first as it has the most to go wrong, the black one is just an adapter which you could probably test with a meter. If it were cost effective i would post mine to you but would cost more than the £5 inc postage lead .
  22. Do you know of anyone else with a working setup that you could try as it could be a faulty lead? I had a similar problem with a setup for reading and modifying a citroen ecu. I ordered another lead from the same seller which proved the first one to be faulty. Contacted the seller who refunded the first lead.
  23. Good work! Is it cost effective to get the part made in Poland rather than in UK?
  24. This type? http://www.ebay.co.uk/sch/i.html?_odkw=m6+vibration+mounts&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0&_nkw=m6+rubber+mounts&_sacat=0
