Tim
FWIW: If it doesn't fart and pop too badly with original map then I suggest persevering with what you have, especially as it worked reasonably well before. Its also a useful baseline to work from. If you use someone else's map then you might find you go back a step. If you have closed loop then a couple of hours should sort out any lean or rich parts of the matrix.
If not closed loop then enrich up across the map (to be on the safe side) and then work towards leaning out gradually.
I found dyno work counter productive but that was because i hadn't a clue what I was doing (still don't really!). Optimiser and decent o2 feedback takes guess work out of it. V11 owners may be able to advise what the afr, in general, is likely to be at various areas. With your mods these may be subtly different. I know I was quite surprised how thirsty my 1100 sporti is - it seems to run best at afrs of circa 12.5 or even lower at some points - but that (as Raz would say) is the dyno-bum method.
There seems to be some recent issues with passwords on the forum - not sure if this is part of your problem. I suggest you email CJ to sort out your access. He is pretty prompt at responding generally but maybe is off chasing thermals with all that hot weather over NSW :-)
gav
