Everything posted by motortouring
FleetwoodMac, Peter Green, brings me back to this years Rory Gallagher Festival in Ballyshannon, with a lot of less familiar bands playing music of Rory Gallagher of course but also a lot of Peter Green. Oh Well(1) and Shadow Play, made the crowd go bezirk (big pogo in front of the stage) to such an extend that the artists feared for their audience. Great time.
Thanks for the clear explanation. I took part in the Round Britain Rally in the UK a few times and then we started to organize a similar style landmark rally with the Dutch Moto Guzzi Club. It sound very much as you describe the Texas Grand Tour. Our objective was a rally that could not be finished and it was all over the European continent from Poland to Spain, the Alps and of course Italy (and the countries in between). 150 Landmarks, and still there is always someone who visited all places. However, in 2005, before Google maps and Google Earth, it was never completely finished by one of the competitors. 2025 is the next Landmark Rally of the MGCN.
Do you have all of the year to ride the GT of Texas?
A landmark rally!
For emission testing the restistance of a vehicle is tested with a coast-down procedure. The vehicle is shifted to neutral (or clutch is applied, not completely sure about the exact requirement) at 140km/h and is coasted down to approx. 10km/h. With this a second order diagram is determined to use on a dynamo-meter. I do know manufacturers prefere tu use bearings and couplings (CV-joints, differential-gears) that are run-in for 30.000km or more. This reduces the internal friction of of the drive-line.
Very interesting topic. And I am again impressed by all the knowledge in this group. I was never in a business with these type of combustion engines that Phil describes, so please see my remark with this disclaimer. We supplied small series machines that were critical to a certain extend and used a preventive maintenance schedule. This included several of the points mentioned earlier like magnet plugs inspection. Over the course of time we were pretty good in using experience from one series of machines to the other. I wonder if this would not be a more effective way to deal with the state of maintenance of our V11s. That said, interesting to find the high amount of copper in the oil sample. It is little extra check, but when checking the valves in 20 minutes more you can easily check the bronze bearings and its axles. And then retorquing(is this a word?) the head bolds is also only a few minutes.
Can you spot the intruder?
motortouring replied to p6x's topic in Special place for banter and conversation
I see a list of important words 😅 Let s not forget Hamburger. -
You can always ask what you want. Buyers might do a lower bid.
I am not sure, I will try and find a spec, but I thought the minimum voltage was often a problem. If I look at the wiring diagram, then I would say that the direct battery connection is part of the solution. Edit: It should be 14.0-14.6Volt https://sunonbattery.com/properly-charge-lifepo4-battery/ 12,6-14.4V is the voltage that I measure. And I use a not-so-accurate digital voltage meter/USB charger. But that is nice to see if the voltage is stable. But as said, I plan to go to the LiFePO4 but the cheap Yuasa is for the moment good enough.
I have used the same and also had a good experience up till now https://www.carmo.nl/index.php?main_page=product_info&cPath=4318_1086&products_id=616 (Dutch supplier of the same, but delivery in one day. I needed that) The one I have is slightly different since it has wires directly on the regulator. This made mounting very easy. The small wiring diagram in the link explains how to connect. This regulator has an overheating protection and a shortcut protection. The output voltage fits also to LiFePO4 batteries. I mounted it at the same bracket as the original regulator. You need to drill some extra holes.
I don't have experience with Lithium batteries yet, but I did buy a new regulator that is also prepared for Lithium (LiFePo) batteries. It is from a supplier in the Netherlands, because I wanted it fast, but the same product can be bought elsewhere. https://www.carmo.nl/index.php?main_page=product_info&cPath=4318_1086&products_id=616 The connection can be directly on the battery. It has internal protection against heat and shortcuts. Mechanically, it does not fit exactly. You have to drill a few extra holes in the bracket. It looks like this one is very much the same as the Shendengan of Guzzler.
@docc the 25% sag, how much is this in mm on the shock absorber? .. Approx.
