motortouring
    8
Everything posted by motortouring
  1. I agree with MartynZ. Great confessions, and such deserved, although late, appreciation and recognition. It must be a warm and Lucky day for you, Phil.
  2. Sorry that it took me so much time to follow your advice. But, I have a full monty stereo set on a LeMans 3. That was an absurd improvement. I changed a few other things, but stability is endless. Whatever you do in the corners, it stays on its path like on rails.
  3. So no stability problems with the longer shock I think I am going to order the long Wilbers for my red frame as well.
  4. If the heads are off, the sparkplug caps are off. You probably pull on the cable to the coil when mounting. This could be a bit loose on the end of the coil. Enough to give a spark in the open but too little under compression. Just some thoughts. But I agree; it sounds like almost everything has been checked already. Are you sure you turned the crankshaft in the right direction? Using the rear wheel to push it forward, for example?
  5. My first suspicion would still go to the ignition. It sounds like the timing is incorrect. Do jo have a stroboscope to check the spark while starting? You probably wiggled the sparkplug cables when taking the heads off. Please recheck everything related to that, connection to the coils and caps and plugs. For the carbs, is that PHF30? Or PHBH30? Main jet is not important for starting. Only for full throttle. That is the last one to improve. You could also share your question on the MGCN site, there are a few top experts on this.
  6. I was wondering if one of you had used an Aprilia RSV Mile or Tuono front fork and wheel, etc. The older ones are rather cheap over here, and the wheels are lighter. I can imagine the standard front forks of Aprilia are a bit better than the V11s. The offset is not that much different.
  7. Late 90ies it was do-able on the west side of the isle, Kirkmichael Glenn Wylln campsite. My god that is more than 20 years ago. Huh, I have more memories than I will ever make. It seems the classic TT in September is a bit of the old atmosphere. A couple of friends went there several times the last 10 years, good stories and a magnet for the old TT riders as well. Agostini, Read (+), and the ones that are still there from the great era of motorsports.
  8. And the lac the Roselend approaching from Beaufort(what she did) and continuing to the Cormet de Roselend is part of the route des Grandes Alpes. Magnificent rides. When sitting good in the saddle you can make it all the way to Nice in a long day. (Or that is what we did when we were younger). In 2021 it took more time when coming back from Mandello >> Col du Tende(gravel) >> Val du Vesubie and further north on same route in the other direction until Briancon. Really lovely part to ride. Bit dusty on the Col du Tende.
  9. One of the little bolts on the front brake switch is missing. Starter button does not always come back when pushed in. Measure the voltage (ca.14.0- 14.4V) when reving to 3500rpm (it does not guarantee the regulator is working properly but it gives an indication) Tools still in the bag.
  10. You can take off the fuel line to the pressure valve. Just to check if you have some good pressure. Do you change your fuel filter regulary? And is it cold in your area? I had 20w50 in my California at 0° Celsius, and that requires a very good battery. I needed support from the jumper. If the RPMs are to low the elect ign will not fire. 10w60 in the V11 is also thick oil at these temperatures.
  11. On the footpeg. And then your clever neighbour comes with a piece of threaded rod or long bold. "Whats that?" "Here 's your footpeg, dont bother the rear brake, we dont use it either,"
  12. Additional motorcycle riding course is indeed very important. I do think this is most effective if you have just the experience to automatically control your bike and you have the basic feeling for brakes and leaning into an average corner. The small block Guzzi's imho are easy to control, have a low seating position, ABS and nicely made. They have acceptable maintenance. For new riders and restarted, I would wish they don't have worries about the reliability and little things that bother the concentration. Anyway, I wish him a lot of pleasure.
  13. I ran into this recall. I m not sure if you were informed already, so just to be sure: https://ec.europa.eu/safety-gate-alerts/screen/webReport/alertDetail/10011252?lang=en Dunlop Sportmax Roadsmart 3 and then certain production badges have an issue with tread separation.
      • 2
      • Thanks
      • Sad
  14. Here in 2021 just after arrival in Lecco. If I believe the story of the previous owner, this 2001 (from chassisnumber) production model was used for the press to ride around Mandello. In 2005 it was sold to the first owner. I was second in 2015. But nothing can be verified. Nice bike though. I also love the color.
  15. I also have that tyre. On this sexyness it did not deliver. But still 5000 to go ... at least.
  16. Anyway, over-reliance (is that correct English) is a serious concern for driver assistant systems. And using the right terminology for functions is a first step to get better understanding. There are by now quite some research results on this topic. More uniformity in name function and how to operate would make it possible to have more generic education for drivers. Now it is up to the sales person and the attention of the buyer if this item comes up at all. I would assume that the camera system has some sort of a verification of the reliability op the perception. Night-time is perhaps a more challenging condition. Is a driver aware of this? Anyway a sad thing. Rear ending without a clear cause is a rare accident over here.
  17. That must be an urban legend. Just like drying the chiwawa in the microwave 😉
  18. 🙈🙈 you 're right, a strange Tarantino project.
  19. It makes me think of Hell Ride https://www.imdb.com/title/tt0411475/ Not a very good movie. As said above, for free it's just okay.
  20. Is it still possible to add an order to the list? Edit: Please put me on the list.
  21. @MartyNZ What you describe is the Guzzi original (alu colored) rack. I have that type on my other V11 Sport 😀 Anyway, ultimately I can adapt the rack so the M8 bolts will fit
  22. I borrow this picture, since I got a luggage rack like this. Like the TS, I also have a mounting problem, but then with this rack. I mounted the subframe and now the rack is next. The subframe has 3 holes for the rack on both sides. The center hole of these 3 is just a 8mm hole that can be used to fix a M8 bold in a threadhole in the racktube. The subframe has nuts welded on the two other holes M8 for fixing with bolts from the outside of the rack. But these M8 can not be used because the rack has 6mm holes. Does anybody know how Stucchi had imagined to do this? I could drill the 6mm holes to 8mm, but it seems their is no room for the head of a M8 bolt. Does anybody have experience with this?
  23. Sukiyaki Django Guzzi
  24. I wonder if Piaggio has a Guzzi that goes faster, than yours. In fact there is nothing misleading in FastGuzzi. 😀
  25. Same case here. I think we will buy a third one for the youngster and sell it in a few years. A v65 or V7 classic or something, like that.
