Everything posted by Kiwi_Roy
You must put those FIAMMS horizontal, any sort of an angle and water gets trapped rusting away the diaphragm When wiring them use something like #16 direct from the battery with a relay, horns are like high quality speakers they benefit from robust wiring. And last of all do not mount them to a rigid surface or it damps the noise out, the little metal plate they ship with them has a purpose. They look like they are fixed to the Aluminium plate but if you look closely you will see the thin steel plate below.
Yes, pull both plug caps With your multimeter measure the resistance from each plug cap in turn, it should measure the same resistance typically about 8,000 Ohms, same on both sides. This is a combination of cap, lead and coil in series. Sometimes Guzzi have used that nasty carbon core lead, it can break contact and cause arcing inside the cable usually misses under acceleration because it's harder for the spark to jump the gap under pressure. Replace with copper core. BTW you should not have carbon lead in series with a resistor cap and xxxR resistor plugs, you only need one resistor.
Combination of heavy rain and dirt or road salt is enough to make the switch track across the insulator, try wiping it with a rag. WD40 is good for this as well.
Looking for Oil Pressure Data for Hi Cams & V11s
Kiwi_Roy replied to Weegie's topic in Technical Topics
I have installed a gauge on a VII Sport, its tied in at the same point as the pressure switch and mounted on the steering damper bracket, yes the pressure is as you say/ I also have a gauge on my 72 Eldorado, it's tapped into the RH head oil feed and shows similar pressure when cold but drops down to 10 PSI at hot idle -
We are talking VII? no, just the ground for the flasher. Some of the more modern Guzzis don't have a flasher at all instead they have 4 dedicated outputs from the dash. I helped a guy with a Griso, his LEDs were still glowing even with the key out and he could measure 8 Volts across the lamp. I have a Griso so I checked into it, I don't have LED lamps but I stuck a couple in to try. It turns out that the dash checks for a burnt out lamp, it tries to pull the output toward +12V to the tune of 40 microamps even when the ignition is off. If the key is turned On and the output goes higher than 3.2 Volts which it will do if a lamp is burnt out the dash displays a picture of a lamp and the red triangle is illuminated. Some LEDs have a high forward bias that may cause the alarm, the Griso owner measured 8 Volts, this probably has several elements in series, The LEDs I have had 19 elements in parallel and the forward bias was only 1.97 Volts and operated without a problem. Simply adding a 1K 1/4 Watt resistor across the lamp is enough to keep the Voltage down when not operating, the resistor should ideally be at the end of line across the lamp. Soldered across the lamp holder is probably the best you can do. The V7 range have a different arrangement based on measuring the lamp current, i'm guessing you need a shunt resistor to run LEDs in this bike.
- 57 replies
- 3
Perhaps just mount a quick connect in the bottom of the tank, there's really no need to shut the fuel off on a FI bike. Do you have an in tank or outside fuel pump? Personally I never had a problem with the Electric Petcock.
No resistors needed but you will need a 3 wire flasher The 2 wire flashers used with incandescent lamps are current actuated they work in series with the high lamp current. The 3 wire LED flashers are more of a Voltage device, they use the Voltage to chassis to activate the relay.
- 57 replies
I think you will need to set it for i pulse per 2 revolutions, I assume you will be picking up the signal from just one coil.The last setting. If you are taking pulses from the ECU its anyones guess. BTW I think a common speedo cabe ratio is 1000 turns per mile
I'm trying to grasp the concept of a speedometer having a set frequency, does not compute.
Heres a couple of pictures of a solenoid, a Bosch in this case but the Valeo or the Chinese one is similar. Note how the long tail has 2 wires Someone came along and interrupted me in the middle of counting turns, I believe both coils were probably 300 turns. The heavy gauge coil is on the bottom so it's thicker and heavier for the same number of turns. Anyone care to check my counting? I only have a British Standard Wire Gauge from my days as an apprentice.
Heres a diagram I did years ago when I had a 2001 VII Sport The red dashed line shows how a 2001 VII Sport was wired from the battery, through a fuse then direct to the 30 terminal of the start relay. that bike never suffered from Startus Interruptus even when the ignition switch was so bad it started dropping out the ECU. Only 100 milliamps ran through the switch. You can check this on Carl Allison"s 1999 VII Sport But then along came your bike in 2004 and for some reason the factory ran the wire up to the Ignition switch and back, big mistake, look at those wimpy wires going from the connector up at the front of the tank to and from the switch this was enough to seriously restrict the current. Check this on Carl's 2004 VII Sport Catalytic The Timing Diagram shows the magnitude of the current through various parts of the starter, the narrow pulse at the left is only 15 - 100 milliseconds wide, the more current you can cram into the coil the better. Actually I have a theory - The factory don't know how much current the solenoids draw. If you take your trusty multimeter and place it in series with the solenoid it will tell you around 10 Amps because the high current pulse is so quick the meter is unable to capture it. So of course Luigi allows a little bit of a margin and uses a 15 Amp fuse. This is confirmed by all the Guzzi schematics that only show one coil in the solenoid. Obviously the factory are puzzled by this, if you look at a modern diagram they don't even show one coil but something like a black hole. If you take the time to measure the solenoid coil you will find measuring from the spade connector to chassis it measures less than 1/4 Ohm. One coil measures just one 1 Ohm to chassis but the other coil in series with the motor is only a fraction of that. All Guzzi starters are similar, doesn't matter what brand you pick. The second coil that guzzi chose to ignore is over 4 x as strong magnetically as the one they provide for. You don't have to re-wire the bike but you will need to keep the ignition switch in top shape. Later model Guzzi's like a Norge also run through the ignition switch but they have the switch mounted to the chassis so the wires are more robust. The Breva is another bike that seems to suffer, the fix there is just to provide a direct feed bypassing the ignition switch, It doesn't change the interlock because the relay coil feed is still switched. Relaying signals from one circuit to another is what relays are good at. Moto Guzzi - making Electricians out of riders since 1921
It could be your solenoid was jamming Chuck, in that case the fuse would have to take 40 Amps on a sustained basis. I hope you upgraded the fuse to a 20 Amp one If the solenoid is unable to slide the gear into mesh and close the main contact a 15 Amp fuse will blow in less than 1 second You can check this out for yourself by taking the large cable off the solenoid, this simulates the main contact not closing, even though the solenoid pulls into place the second high current coil stays in circuit. Note: its not just Valeo starters this applies to, The old Bosch, and the new Chinese starters currently used by the factory also have two coils Im willing to bet the ones sold on the internet also have the same 2 coil arrangement. I do wish Guzzi would show this on their diagrams.
The most common problem with Guzzi starters is lack of current for the solenoid, it would like to draw between 40 and 50 Amps.To get this current you need almost zero resistance. The way to test your starter is to take a wire from the solenoid and touch it on the battery, if it responds to that then its another fault. A word of warning, make certain that the bike is in neutral or on the centre stand so it doesn't launch itself. See Stewgnu's post, thats typical of too much resistance the solenoid sits there drawing not quite enough to pull in 20+ Amps The easy way to get around this is to provide a direct feed to the starter relay, this will send up to 40 Amps to the solenoid guaranteeing it will pull in. Cleaning the ignition switch and sprucing up the relay socket may get you off the hook for a while.
I seem to recall the speedo needle on my Vll in the vicinity of 240 kph, is that even possible or am I dreaming?
It shows it that way in this early document 1989, https://dpguzzi.com/efiman.pdf This is a great read if you want a basic understanding of EFI Connected to the manifold it would constantly be changing the injector pressure, I imagine it would put a lot more strain on the regulator and probably made it tricky to calculate the Mapdirect As it runs now the injectors run under choked flow conditions, the manifold pressure has no direct effect on the injector flow rate, thats a function of the ECU calculation. The ECU includes an Absolute Pressure transducer that signals so it can compensate for Altitude by changing the open time. Of course it also included revs, temperature, throttle position, battery Voltage and a few other parameters in the injector time setting (just not by tweaking the supply pressure)
Keeping the Clutch Disengaged / Bike in 1st at a Stoplight
Kiwi_Roy replied to Kane's topic in Technical Topics
I use a range of techniques actually, first of all I try to avoid having to put my feet down, so I time it to catch the green, hold the clutch in for a short light, try not to stop directly behind the vehicle in front so I don't end up the meat in a sandwich and turn the motor off for a long light, it also varies depending on what bike I'm riding. Luckily I don't have to negotiate busy traffic on a daiiy basis or l would probably give up riding. It's a good discussion, good to air different points of view. -
In 2001 they had an electric petcock.
The riding schools teach you to sit with first gear engaged ready to drop the clutch Lately I have been stopping the engine with the kill switch then turning it back on, a quick jab on the starter button and I'm away. -
It can drop right down to 10 PSI or less while idling hot but should sit around 60 at 2,000 revs. I had a gauge mounted on the steering damper bracket, you can hard pipe it there with copper. You also get full pressure from either of the head oil lines. What really gets your attention is the pressure dropping to zero under acceleration if you let the level get too low on the dipstick. If you don't run a Roper plate you must have a gauge IMHO, the light would likely not catch that event like a gauge.
I have zero confidence in the Guzzi presses switch. if you crack the fitting going to one of the heads it will soon let you know if there is oil pressure or not. I suggest you add an oil pressure gauge, oil is normally ~ 60 psi Update I thought I had mentioned that the switch tracks across the dirty wet switch insulator, usually all it takes is a wipe with a rag or spray with CRC For most of my working life I designed industrial instrumentation, you don't buy anything and expect it to work reliably unless it makes sense, a pressure switch that works by distorting a tiny bit of metal a microscopic amount to make a contact makes no sense at all. An industrial switch would have a decent size diaphragm working a snap action switch however switches in an industrial setting are a pain in the arse, we would usually specify a pressure transmitter that could be trended and do the switching in a computerized control system.
I like that as you say you would be able to replace it until you have a chance to solder another in. I had one fuse weld in so I cleaned up the contacts and tightened the clips and it never re-occured. I always meant to look at the current with an oscilloscope, I'm sure the peaks must be well over 30.
I;m assuming you have one of the later VIIs with the Start relay powered from the Ignition Switch Typically there is too much resistance in the ignition switch and it's associated wires. The Starter solenoid has two coils one that pulls 10 Amps and another that would like to draw 40 Amps but just for a few milliseconds while the solenoid engages and the main contact closes, This is such a common problem it's been named "Startus Interruptus", common to almost every other Guzzi right up to the latest. You need to clean the ignition switch every few years, take the switch block off the lock (2 Phillips screws) and open it up, wipe out the old grease and replace it with fresh Petroleum Jelly aka Vaseline. There is a permanent fix (strong feed) that requires a direct connection to the start relay 30 terminal from the battery but it also requires a different arrangement for the feed to the headlight relay, try cleaning the switch first. Drop the negative wire off the battery to make it safe. I think your problem with cutting out is possibly a dirty side stand switch, carry a short length of wire to stuff in the relay (15) socket 30-87, this will bypass the stand switch as a test. Further reading https://www.v11lemans.com/forums/index.php?/topic/21206-startus-interuptus-revisited/
Why do you need to disconnect the wires? Chop the connector out and use a couple of crimp links or solder the wires. If you ever need to replace the wires make them a bit longer so if you ever need to chop them you have enough length to shorten them. Heat is resistance x current squared and I believe the current spikes are very high leading to lots of heat. Also i think the crimp connectors available in The America are smaller than the OEM Guzzi ones.
The 2000 will have 2 relays in series feeding the headlight, Start relay Normally closed and Headlight relay Normally open, the Voltage reference is tapped into the wire part way along the tank so its subject to the Voltage drop I mentioned. You will see this if you measure between battery Positive and the Black wire of the regulator The previous owner may have upgraded the regulator already. If it still has an ancient Ducati Energia regulator definitely add a ground strap from the regulator to an engine bolt and consider a method of eliminating the Voltage drop. On the other hand the starter wiring on these early models should never have a problem, the start relay is fed direct from a fuse. Clean the ignition switch, and change the side stand switch, this model can get very dirty before it starts to drop out the ECU Guzzi Wiring - Simple.pdf
I believe that happens because of the flakey Voltage reference downstream of the headlight relay. This is particularly bad on the earlier bikes where they had two relay contacts in series with the headlight current, The Voltage the regulator sees is normally about half a Volt lower than the battery Voltage but if the bike has been sitting for a while I have seen mine as much as 1 Volt lower. So when the regulator sees a Voltage 1 Volt lower it jacks up the charging to compensate and the charge current goes up exponentially which will overheat the diodes melting the leads off. My first experience with this I was able to remove the potting material and re-attach the leads to get about another year out of the regulator, I also took the opportunity to reverse engineer the circuit. Finally I decided to fit a direct connected regulator, this solved the charging problem however it did add a small residual current that would flatten the battery if left over the winter.
