rossi46
    14
Everything posted by rossi46
  1. ah well spotted, tank off time I guess!
  2. its directly opposite the fuel tap on the right hand side of tank
  3. I only had one hose aswell.I put another on just in case the parts diagram seems unclear, I guess the right side is the most important,geddo what does the regulator look like? is that blocked ? could that be the issue?
  4. are you talking about the 2 nipple type outlets? one (i think) is a breather the other will drip fuel if its overfilled, there should be 2 black hoses attached-if theres some 'plumbing' issue and the tank is pressurised maybe fuel is seeping out here?
  5. ahem to that! reminds me of an old Russian joke- son says to farther 'so will the price of vodka mean you will be drunk less? no son it will mean you will be hungry more'
  6. Having spent a frustrating morning in the garage pipe bending-burnt forearm! I'm no nearer that bloody nipple!!!!!!!!!!!!!! so I guess its wheel off, will the bevel and shaft just slide off? I have the alignment marks already on it, just line them up on re assembly? thanks
  7. defo sounds like rear brake-mine does it on occasion especially after some wet riding-a good clean with an old toothbrush and some hot water should sort it-
  8. could it be the auto fuel tap not opening fully?
  9. What a timely post! I've just borrowed a blowtorch to try and bend a grease gun attachment My link failing that, bearing in mind my lack of skill, whats involved in removing the shaft to grease the uj?
  10. My 2000 sport is sitting on 76,202 miles (122,635 Austrian kilometers) just passed 16000 on my commute today
  11. on my ever growing to do list My link
  12. Thanks none on my bike!! I guess something like this will do My link
  13. Heat shield? what does that look like? I don't think I have any on mine! or is it only on US bikes? http://aprilia-spares.com/MGParts.asp?mod=GU08602&tbl=24&tblname=24%20Fuel%20vapour%20recover%20system
  14. morning all, Has any one done this to the clutch and rear brake? I've seen on eblag people selling syringes for this and wondered if it would be be a better method, suck out old fluid through the nipple then fill the same way forcing any air out the m/cylinder as you go-any thoughts?
  15. TREVINI tyres are great-no probs even in heavy rain
  16. Thanks for the input guys - I finally went for a Becker stand- nice bit of kit,I too had trouble getting it up so I just tightened the wheels to stop them rolling-oil change on the weekend then
  17. thanks guys I was intending to drop the sump but figured that (considering where the drain plug is located!) there would be some oil left in the pan and it could get messy!
  18. Hi I'm bracing my self for my first oil change, what tool do I need to remove the manhole cover on the sump(what size)27mm? and which is the drain plug at rear of sump? cheers
  19. theres one for sale on the GB club site
  20. http://cgi.ebay.co.uk/Guzzi-Roper-V11-Windage-Plate-Sloppage-Sheet-/290542611221?pt=UK_Motorcycle_Parts&hash=item43a5b06b15#ht_500wt_944
  21. nice work as ever roy! wish I could do mine but I'm sure it would end in tears!
  22. velf shall we start our own registry
  23. yes it has the '11' in red
  24. ok then http://www.gutsibits.co.uk/pr/TheShop/index.php?f=e&Cat=ACA&CatName=Accessories&Shnew=1&ModelName=All&spPage=1#topbar
  25. try My link
