Hi
No, I read about those, not on mine though.
There is a small inlet leak - seems equal both side and on the btm of the butterfly spindle. However, it was fine three weeks ago so I think I'm after something - maybe a sensor going out as richening the tps temporarily cured it. Now it's back.
Can't ride it at the mo, too bad.
Am I right in thinking then that you can't adjust CO on my ECU?
...also, what would be the effect of a bad air temp sensor. Mine checks OK (3 Ohm), but seems to run the same with or without it connected?
Rob
