kglm
    2
kglm last won the day on February 12 2019
kglm had the most liked content!
About kglm
  • Birthday 01/26/1965
    v11 lemans -02 , LM IV -87 & DR 650 -92&93 , V85tt -soon..
kglm's Achievements
Guzzisti
Guzzisti (2/5)
29
  1. kglm
    kglm
  2. Music for truckers; I have a itch.. that gigs of CC & Airmen was Great Fun at the time -KG-
  3. there is hope in the world! (I dont like RAP ) -KG-
  4. http://www.motoguzzi.com/mediaObject/motoguzzi-sites/US/V85-brochure/Moto-Guzzi-V85TT_digital-1-/original/Moto%20Guzzi%20V85TT_digital%5B1%5D.pdf English Motociclismo -KG-
  5. I use same method as Footgoose , but i remove front subframe away to get more space -and front fender , not to scratch. Check timingcover gasget, if it`s poor old-fashioned paper gasget -those break sooner or later - now it ´s wise to replace new metal type. -KG-
  6. Yes , a strong recommendation -very good shop. -KG-
  7. You don't need 100+hp when travel that kind of bike -only racetrack , not on road. -KG-
  8. ...previous owner used cold chisels to change the tires... I just use "airplane model paint" to fix those marks. -KG-
  9. Scotland
  10. Yes! I "tested" tank volume last summer; empty tank takes 19.5l -totally empty (pump inside) measured volume 21.7l = 2.2l in trap -quite a lot -KG-
  11. You mean the raised portion points to the front of the bike? if so that is what I did. Andy Your friction plate(s) in photo post #8 is backwards. Turn raised side pointing to gearbox like my photo in post #20 -KG-
  12. Season 2016 i have a same kind serious running problems , less than 2000km that summer. Two bikeshop try to fix it -no result. Next winter i change all relays to Omron (have to order them US) and now it`s running ok. I use carbtune and i don't try to get exact same balance but instead best possible and when meter columns react same kind -rise and fall. Bypass left 1/4 & right 1/2 turn open. -KG-
  13. Yes , it should be turn. -KG-
  14. TB sync and first ride this season -KG-
  15. Yes -airbox it´s clean. In that extra bottle theres always spoonful or two oil. I have used Liquimoly 10/60 and last two years Motul 5100 15/50 , both acting same way. Bike is very used ; about 165tkm -KG-
