Everything posted by kglm
I have that "ugly" rack ,-but with modifications: lower mounting points are different and rack itself is bolted also different way. It´s two minutes to take it off.. Because: it is very ugly.. -KG-
I believe that original little flexible rubber joint is here for good reason -safety- -KG-
..here`s mine in seal repair 2012 and 121000 km - works ok since and now + 50000km , still original plates -KG-
If you just fix leaking there no need remove axels: take off first cover , use 01912530 support tool and turn box , all axels stays in place second cover. -KG-
http://www.henkel-adhesives.co.uk/2838_UKE_HTML.htm?nodeid=8797713235969 I use this , now 100 000km after fix. ... home made special tools 01912530 is what you need, - i open the box just using normal tools ... -KG-
160000 km ,-one spring change -KG-
Duhhh. I feel stupid now. That is part of it. Thanks for the clue, I needed one! Engine is also off the center line , 13mm to the drive side ->right. -KG-
..not perfect but better than original : o-ring 2.5mm ,under that dremel modifed sideplate from old front wheel bearing. -KG-
v11 LeMans 2002 LeMans IV 1987 Suzuki DR 650 1992 Wilier Triestina Izoard XP 2011 Cube Reaction GTC 2013 -KG-
Single malt - what are you drinking?
kglm replied to Denis's topic in Special place for banter and conversation
Ardbeg 10 years. -KG- -
I believe BMW use same bush , -and sold them separately. Bush is Hostra st 1230-2834 -KG-
timing cover gasket, metal or original gasket?
kglm replied to SanderVdB's topic in Technical Topics
Updated metal is better choice. -
What is best grease to buy for the drive shaft u-joints?
kglm replied to 4corsa's topic in Technical Topics
Lubrication Engineers 3752 -Great stuff- -KG- -
Just replaced a leaking engine sealring ( no slipping with that ) to new one. Clutch plates totally dry and measured 7.8 mm => back again.. 120tkm touring ride. -KG-
Hi Wilbers here too -they can build it just like i (you) wanted.
Dry place +5 C or more, new oils, battery disconnected (charging every second month)..waiting...waiting....and after six (6) month waiting winter is over !!
V11LeMans.com Continental Meeting 2010
kglm replied to Admin Jaap's topic in Meetings, Clubs & Events
Nearly last.. -Good luck with new clutch There was about 30 cars & scooters at park place, so maybe they build new Guzzi`s ? playing cards ? tasting chianti ?
