Bill Bassett
Everything posted by Bill Bassett
I hoped it would do someone some good, I always liked having a spare. I'll offer up some more spares shortly. thanks, Bill
The ECU is sold. Bill Bassett
These are sold. Thanks, Bill
I think the ones I have left are the lower mounts. Someone already bought the upper ones. I don't have a picture account so if you'd like pics, send your email address and I'll do some pics. thanks, Bill
Foot, I have a pair of Ti mufflers. The right one is perfect with the connector pipe and the mounting strap. The left one is damaged; but I think the end cap could be removed and the dents rolled out. The connector pipe has rash on it, but usable, also has the strap in good condition. I'll send pics if you send your email address. Pics tomorrow. Bill Bassett
Stan, I still have it. As far as I know, they're the same. thanks, Bill
I'm selling a spare ECU I had for my V11 LeMans. IAW15M.C7 is the part number described for MG V11 Le Mans MY 02. It is used and is in good working order. I'm asking $135.00 USD shipped anywhere in the lower 48 included. I can send pics if you want, provide email address. thanks, Bill Bassett
Foot, I guess I should have proofed my listing. I have one pair of high mounts that come with the Ti mufflers and one pair of mounts for the lower mounted mufflers. I think that's more clear. thanks, Bill
I have 2 pairs of freshly powder coated V11 muffler hangers, one pair of mount, one pair of low mount. I no longer need these. $100 per pair. If you want pics, send an email address. thanks, Bill Bassett
Titanium mufflers and inlet pipes from Rosso Corsa. Right side is excellent. Left side is damaged on the front plus the connector pipe is bruised. I think the muffler could be disassembled and the end repaired. Send your email address if you want pictures. $450 for the pair, shipping included. thanks, Bill Bassett
One pair original mufflers from 2003 Rosso Corsa. There are no scratches or dents and are the semi gloss black metal, not carbon fiber. If you're interested, send an email address and I'll send you pics. $150.00 plus $35 for shipping in the lower 48. thanks, Bill Bassett
Motratech (or other) dropped pegs likes/dislikes
Bill Bassett replied to Gmc28's topic in Technical Topics
GM, Looks like I got the bits mixed up. I have installled both kinds. The linkages are adjustable for proper lever placement. I do like the Techs over the bits. If you were a little closer, you could swing by and sit on the bike and see how they fit you. Back to changing my tire---- Bill Bassett -
I've had lowered footpegs on 3 V11s. Motobits on my 03 Lemans, Motrabits on my Coppa, and Motrabits on my 03 Rosso Corsa. I liked the Motrabits the best for comfort. I am also fitting a set of adjustable clipons to the Rosso. The Motrabits are more expensive, but they are well made and have a good fit. If you do get them, pull the starter and the cylinder for the rear shock first thing. Bill Bassett -
Annoying Exhaust chirp with baffles removed
Bill Bassett replied to Bill Bassett's topic in Technical Topics
This is a pic of the completed modification, needs a little more sanding. I'm past doing a video. You can just imagine a nice deep sounding exhaust tone and you'll have it. Bill Bassett -
Troutman, I fitted a set of the Motobits foot controls on my 03 Lemans when I had it and found them to be more comfortable in the kneebend. I fitted a set of Motratech controls to my Coppa and found them to be even better as far as comfort. The Motratech set includes both brake and shift levers and everything required with appropriate proportioning as far as length and angles. Bill Bassett
Now you're challenging my internet skills with the pic. I'll take one tonight and try and get it on tomorrow. Mistrals reverse carbon fiber, mounted low. Bill -
I recently purchased a new pair of carbon fiber mufflers for my newly acquired Rosso Corse. I did not want to run it with the baffles installed. When removed, there was a chirp at idle and more pronounced when advancing the throttle. It was suggested for me to put the little clips back in place without the baffle. The noise was reduced, but it looked funny with the clip and no baffle. The chirp comes from the hole in the end of the pipe that holds the baffle clip. I eliminated my chirp by making a stainless ring 1/2" long with an ID the size of the OD of the pipe. Make it fairly snug, clean the ring and the outside of the pipe and put a thin coating of JB Weld around the inside of the ring and fit it over the end of the pipe till flush. Wipe away any excess. Put a little JB on the inside in the little cavity left by the hole. Let it harden, sand the inside if you have been a little generous with the JB. No more chirp. This is more or less permanent. You could figure another way of fitting the ring if you want to be able to install the baffles again. Also, this may not be an issue on the type of mufflers you have selected. Bill Bassett
Does anyone have an undamaged red valve cover from a Rosso or Coppa that they would sell. I purchased a Rosso Corse that has been down on it's left side. The right side is perfect. thanks, Bill Bassett
Scud, I would like one of the Roper plates. thanks, Bill Bassett
ANSWERED V11 Oil Pressure Gauge, Best Practices?
Bill Bassett replied to JBBenson's topic in Technical Topics
I have the Motratech oil pressure gauge setup on my Coppa. It is a well thought out setup that fits perfectly and has worked without any problems for 3 years. After reading about the red lights under acceleration, I questioned what sort of oil pressure I actually had. Mine runs about 60 psi when cold and 55-56 when hot. I also have a "Roper plate" installed. Bill Bassett -
1. SRL, Florida 2. sttrecker, Phoenix, AZ 3. VA Sean Virginia 4. ciV11 San Jose, CA 5. hoytstaab Seattle, WA 6. RWalker Lawrance, GA 7. Orangeokie Oklakhoma City, OK 8. Ghostrider Jefferson, TX 9. motowfo Kirkland, TN 10. Todpc White Mountains, NH 11. Falcolion Brooklyn, NY VIN 4M111273 12. Jagwillie Wyoming, RI
Motobits vs. Motratech Peg Relocation
Bill Bassett replied to al_roethlisberger's topic in Technical Topics
I think it's mostly geezers with bad knees that have these bikes. -
I just put a set of the Motratech controls on my Coppa and am pleased with them. They come with good instructions and all the necessary hardware and are not difficult to install. My knees are glad I made the conversion. Bill Bassett -
I have a good used spare one, complete from a low mileage 03 Lemans. $275 plus shipping. Let me know if you don't come up with a better alternative. Bill Bassett
