parkjnl1
Everything posted by parkjnl1
  1. parkjnl1
    parkjnl1
  2. Thanks, I guess it's just a Guzzi quirk.
  3. Ok so upon really getting into it I have found that the Black/Red wire side of the indicator light is 12volts the Blue wire side is 12volts and when grounded the light comes on. Following the blue wire it turns into the Black wire at the connector at the Voltage regulator. There is 0 Ohms of resistance between the connector at the regulator and the light socket leading me to believe there is something wrong internally in the regulator not grounding the circuit. The bike is charging at 14.7ish volts. I guess I should buy a new regulator or can live without the telltale light although it would be nice to have. Am I correct in thinking the regulator has failed? Thanks
  4. Thanks, I'll check it out
  5. I do not know if the regulator is original. Honestly I don't know where it is. I bought it used so I don't have much history. Where is the regulator located and which color wire should I test
  6. parkjnl1
    Charge Light
    Is the charge indicator light on a 2000 V11 Sport supposed to come on when you turn the key on without it running or does it only come on if it's running and there is a charging failure? I was replacing the bulb for the turn indicators which was burned out and I just can't remember if the charge light was ever on. My alternator is charging (I tested at the battery) This leads me to believe the ground may be bad but all of the other lights work. Added later.... I thought I was going crazy so I double checked but the socket for the charge light has 12volts on BOTH sides and when I ground one side the light comes on. I'm confused Thanks
