Everything posted by Chuck
I was showing my pup Austin how to adjust valves a few years ago. I told him you want it to feel like it would if you put it near the spine of a phone book, closed it, then pulled the feeler gauge out. He said, "Phone book?"
Guzzi V11 Le Mans 2000...Starting issues
Chuck replied to David Sandbrook's topic in Technical Topics
Not very wise here.. but a common failure is the voltage regulator from a dodgy ground. This would have let the battery run down. If it was truly 0 volts (!) it may be dead even though you charged it. Battery's don't like being totally discharged. Once you have replaced the voltage regulator and ran a solid ground from the regulator case to the engine block and most likely replaced the battery..report back. Oh, and welcome to the best knowledge base on the V11 in the world. Somebody else may have a better idea than me shortly.. -
Beat me to it..
I'll take all that off your hands.. and use it.
Pretty awesome.. thanks for that.
From memory.. always suspect with me I fixed one like that with a broken solder joint at the ignition switch. Green wire, I think..
It carries on. Colt, the MS's latest keeper, was on it at Guzzi lunch one day instead of his Grease O. He started the old girl up with the glorious sound from the Staintunes, and I said, "She's a bad MF er." He just smiled, and said, "I like it."
Well, at least Bev is getting better.
Sounds like a warranty issue to me. Want The Kid's phone number? Oh, never mind.. He and Nora are on vacation. Hell, it's just a machine. Fix it or have it fixed. They aren't making any more of them. Hope your sweetie's ok..and all the best to you, too, John.
V11 Ballabio 2004 - Weird electrical problem after storing bike 1 year
Chuck replied to vinguzzi's topic in Technical Topics
Experience is a tough teacher. She gives you the test first.. then the lesson. Oh, btw.. a bad neutral switch wouldn't make the headlight stay on after turning the ignition off.. -
First I'd load test the battery. Voltage readings mean practically nothing. Once I knew the battery was good, I'd clean and apply fresh Vaseline to the ignition switch. Spritzing Caig DeOxit on the relays and relay bases is always a good thing. -
Hoo wee.. I had the VFR's younger 600cc brother with it's top end oil delivery issue. Fun machine though, once sorted out.
Yep. The first thing to learn is that "it ain't a Honda." It *is* a kool machine, though, and worth the trouble to learn about it.
PM me your mailing address and for $50 US plus actual postage that can happen. I also have an unbreakable pawl spring if you want one.. another $10 if you want one thrown in the package. Supply is (ahem) *very* limited..
Yeah, WG is a shadow of it's former self since.. oh never mind.
On airplanes, the cylinder needing checked is put at TDC compression stroke. The prop is dangerous and is held tightly before turning on the air. The regulator sets the first gauge at 80 psi, and the second gauge shows the leakage. The prop then can be turned back and forth a degree or so to get the highest reading. A normal cylinder will be 75 psi or above. I don't get terribly concerned until it reads 70 or under. This will show leakage from rings at the crankcase breather, intake valves at the carb, or exhaust valves at the (wait for it) exhaust stack. It won't tell anything about valve guides, but since it is at TDC you can feel how much clearance there is by wiggling them around. Edit: I would put an on/off valve on the hose to the cylinder on the pictured rig. It makes things simpler.
I would think that if there was *no* oil, maybe 50 miles or so would Donald Duck it. If there was some.. maybe you have dodged a pretty big bullet, but there also might just be some pretty blue gears/shafts. There's really no reason for no oil unless someone forgot to fill it. Most likely is the linkage is not adjusted properly as mentioned above for the shifting problem..
Docc, from the look of those plugs, I would do a leak down..just to have an idea of general condition of the rings/valves.
That is one of my favorite parts of the country. I *love* Beartooth, but have only done it in late July and early August. Cody to Chief Joseph to Beartooth down to Red Lodge, than back up to Yellowstone is one of my most memorable rides.
Air condition/ heat shop "mini-split"
Chuck replied to PJPR01's topic in Special place for banter and conversation
Quite a bit easier and didn't have to (cough cough) buy a vacuum pump and gauges. (Guzzi content) -
I just coiled the excess behind the evaporator. A hivac guy I know says that is actually a good thing.
