stefano
About stefano
  • Birthday March 29
    '02 LeMans '07 F800ST '94 Miata
1,304 profile views
stefano's Achievements
Guzzisti
Guzzisti (2/5)
2
  1. stefano
    stefano
  2. congratulations to you & your wife czakky, daughters are a blessing. i hope you're passin' out cigars.
  3. ah shit, that really sucks, i intend to have a beer in his honor, godspeed.
  4. stefano
    Are V11 Airheads?
    i used to get parts from the dealer in beaverton (portland oregon) my (then) closest dealer. no problems. haven't dealt with the new dealer in portland yet. you have the premier dealer moto international in your backyard in seattle. couldn't be better.
  5. try turning the bars left then right while thumb on the start button next time it won't start. this remedy is for the barrel connector problem, very common. rode mine for a few years like this. and the advice from fotoguzzi & bsmarble has merit. if you have a foam pad on top of the tank, it is a re-badged '02, there were a few changes in '03..
  6. ya know on further thought i think docc's advice on moto international is a good one. they are experts on anything guzzi. if you want someone to go over it & check it out i'd also recommend them as you're (relatively) close. i'm about 125 miles south of them, but the traffic from olympia north is a dealbreaker for me. seattle traffic is the shits. if it was me (and it's not) if the bike runs good, i'd change all the rubber parts, fuel lines, throttle body rubbers, for sure the breather hose, (they're all 12 yrs old regardless of the mileage) fluids & filters adjust the valves, (this is simplicity itself) i've just done all this on my '02. docc also has a thread *while the tank is off*, easy to find.
  7. i think there's a few members in your area, i'm sure you'll hear from someone. i notice you have a commando, i suspect you're fairly adept with tools, as i had an 850 commando for many years. enjoy the guzzi, steve
  8. stefano
    New Battery
    replaced the original spark with a PC545 couple years ago. very pleased with it.
  9. if the keys work in the gas cap i suspect they're the correct for the ign. also. have you tried them in the seat lock? its on right side of bike a wee bit higher & in front of the right footpeg. the only advise i can give is not to *force* the key, but you already knew that. i didn't know your father, but i know i'd like my ashes shot out of a cannon, i think he's probably smiling at the prospect. i wish i had a larger cannon, i'd help you out. screw the red tape. steve
  10. a beauty for sure, love those two-tone paint schemes. yeah, your clutch sounds pretty normal. noisy, but fairly bullet-proof. my rubber parts were getting cracked also, i've just replaced the throttle body boots, all the fuel lines & the breather tube, filters, etc. etc. etc. i did find the tank R&I a PIA, but i guess if ownership was simple, everybody would be riding one. they should be so lucky.... good choice,have fun
  11. thanks for this. i'd never seen my build date, didn't know it was there. kind of easy to see now as i've got the fairing & tank off for some maintenance. interesting, my '02 red & grey Le Mans was built in july 2001. cheers, este
  12. sorry about the bad luck. but you know, it's really about riding. put together a few more bucks, get a new bike with a japanese name on the tank and enjoy the summer.
  13. Thanks you also for your good words! Actually I do also notice more wind buffeting with this windscreen, although it did remove the squealing that my Shoei RF1200 was creating without the screen in place. But the buffeting is slightly more annoying and certainly more damaging to the ears. I did not think that this screen would be able to be modified by cutting! Can you explain further how the edge trim is finalized after cutting away the un-needed area? some folks lower them with a jig saw, but i found it easier with a 4" grinder with a 50 or so grit sanding disc. maybe draw a line with a marker. it shapes fast, and be careful, one slip, well you know... i did my MRA in stages, then would go for a ride, it didn't quiet down 'til it was nearly standard height & shape. then smooth the edge with a file or sandpaper or whatever. BTW my avatar is before i cut it down, was very wind noisy for me (yes i wear earplugs) YMMV
  14. very clean looking conversion, you've done a good job. you mentioned that the MRA screen is taller than you thought it'd be. i have one on my Le Mans, it was so much noisier than the stock screen (guess i need clean air) ended up using a 4" grinder with a sanding disc & shaping it almost back to stock height. then draw filing edges smooth, works (& looks) great. just a thought. keep up the good work
  15. ya know, i don't get huge front tires, or torture saddles but i kinda like it.
