The first video docc has subtitles. I hate to say it but it's rather neat and well thought out and engineered. Not made to negotiate corners of course but then neither is a Harley. Ciao
Possibly, but the yardstick for HP and torque measurements these days off a chassis/rolling road/inertia dyno is wheel HP and torque. Not that it's completely comparable between dynos as they are comparative measuring devices but 103HP was a figure that just jumped out as way too high. If you do want to gain yourself some bragging horsepower on an inertia dyno just fit a racing slick and wheel for the dyno runs and you'll pickup a few HP for free. Ciao
In-Tank Fuel Pump Electrical Question
Lucky Phil replied to Tom in Virginia's topic in Technical Topics
Yep and plastic tanks as well. Ciao -
Hmmm.......I hope you dont believe its anywhere near that figure. 84HP is about the best you'll ever see from a stock bike with exhaust and tuning upgrades. Ciao
Look up Pauldaytonas website paulsfastguzzipage. He has made these in carbon in the past. http://www.fastguzzi.nl/ Ciao
Yes, but aircraft fuel tanks are vented much more effectively than a motorcycle tank in that they are virtually open to atmosphere by large vents. There was a 737-800 that caught fire at the gate in the Philippines a while back as well from memory attributed to an ctr tank fire.I think from memory it had to do with very hot weather, low tank qty and a/c packs running for hours as contributors. I'll need to look it up. Commercial jets also have their pumps in a dry bay usually to isolate them from the actual surrounding fuel which makes the tank fires even more unusual, that combined with JetA1 being way less volatile than gasoline. Ciao -
There is an old demonstration I saw 40 or so years ago of an arcing wire submerged in fuel, just arcing . To get an explosion you need 3 components, fuel, an ignition source and oxygen. Under normal conditions the tank has only 1 of these, fuel. I'm not entirely sure that a closed tank with low fuel would actually have enough oxygen to support ignition if arcing did happen.An open tank would be another thing though. Why would you need to do any wiring repairs to replace the pump? aren't they all plug connectors in there? Ciao -
Interestingly docc the later bikes had an 8mm bolt here, maybe to address the loosening issue. Ciao
The Griso 1200 is the best solution. The camshaft is now a jackshaft driven from the front by gears and driving camchains from the rear to high cam heads. Water cooled, 4 valve high cam with the drive from the rear of the cylinders, roller lifters, no pushrods, compact heads. It's a much better engine than the Daytona. Not as good looking but far superior. Seriously, air cooled engines these days are a bit silly as are 2 valve heads and pushrods. If you like the looks then still have some decorative fins but the advantages of water cooling are so great that using air cooling makes no sense at all. What Guzzi could have done in the 90's was a Griso style rear drive via chains to 4 valve hi cam air cooled heads. Alas they didn't have the budget to cast up all new cases so they used std big block cases and so were limited to driving the cams front the front. The MGS-01 ditched the jackshaft ( which replaced the cam shaft) and used a short stub shaft supported by a ball bearing in the cases where the front jackshaft plain bearing was and also used a needle bearing in the end of the camshafts instead of the plain bearings. Ciao
Ah, finally our go to electrical guy arrives:) Ciao
First bike I ever crashed. Ciao
Yes docc, lovely car and bike captured together. Ciao
Any Experience with HyperPro Rear Shock on "03 LM?
The Hyperpro looks good but dont exclude Wilbers as an option. I've worked on Ohlins (Proper race Ohlins as well as the "production" ones) Penske, Marzocchi, Bitubo and the std stuff and the Wilbers is a high quality unit they will build to a spec for your use and weight. I've run one for years. Just putting it out there as another option. Ciao -
Yes, its a sick feeling being behind someone with the side stand down trying to warn them and seeing the inevitable looming. My bike doesn't have a self retracting side stand, I dont know any Guzzi that came with them? Why would you de activate the switch unless you were stuck somewhere? Ciao
Yes thats the best part. Ciao
All of these things in combination have stopped me from using one of these deep sumps although I like them very much. The other issue is you lose your oil cooler and can only fit one via a fairly untidy oil filter sandwich plate and AN fitting hoses. The best way around the side stand issue is the weld a machined lug onto the side of the sump for the original style V11 stand bracket which incidentally comes in 2 versions, 1 with a 6mm bolt and the later type with an 8mm bolt. Even in European traffic the engine will get hot with one of these sumps with the extra capacity and paul Daytona has fitted a cooler as well on his Daytona. He has also used the daytona bracket without the additional bolt for years without an issue apparently. In my view the sidestand cutout is a mandatory function, either that or the less appealing self retracting side stand. It only takes one lapse to cause a nasty and very possibly fatal accident. I've witnessed one and heard of others over the years. Ciao
I'd rectify that myself. I've seen a nasty accident from a side stand left down and heard of more than 1 fatality from it over the years. If you dont have the safety switch then it needs to be self retracting for mine. Ciao
Roy is the "go to" man for the electrical stuff. Ciao
Bravo to NicoNZ then. I skim too much these days. Ciao
