Lucky Phil
    257
  1. Whats the fuel pressure like? have you changed the fuel filter? Ciao
  2. Winner,Winner, chicken dinner:) Ciao
  3. Ok will do. I'd love to do a tree change and it's on the cards. I'd just like to get out of the city/suburbs even though i'm on the north east fringe now I'd rather be in the "country" I'd like to move back to the south coast of NSW near the sea for the nicer winter weather. I'm from Sydney originally and now I'm retired I'm sick of the grey overcast Melbourne winter weather. The temps dont bother me but the lack of sunny days sure does. However my eldest daughter is moving down so that plans out the window I think.I'm looking for a nice country town in Victoria with good services and sunny winter weather an acre of land and near the water if possible. I need to be on that show myself. Ciao
  4. Yes feel and weight transfer were the major shortcomings. #1 priority on a race bike is front end feel. If you don't have that then everything else is wasted. The only people that had anything good to say about racing any of these style front end bikes were the people that had sponsorship ties and were paid to ride them from the Elf project on. Ciao
  5. No guarantees here but I hope its a factor. I'm trying to actually remember all the steps for the process as it worked so well for me I never had to contend with any problems other than forgetting I had the kill switch off at one point. ciao
  6. You outline the issue I had with mapping the Daytona engine from a different ECU but it's not the headache you might think just time consuming and you can use Tunerpro to look at plenty of other peoples .bin files to shorten up the process. So when I needed to use the Daytona/Centauro mapping from a 16M ecu to a 15M ecu ( both use different XDF files to read the .bin files) I was also able through the generosity of others around the world to read a lot of other .bin files for standard and modified maps and use them as a reference. You can read the process in my build thread but essentially I had enough information on maps to look at what had worked for others and mix and match to suit what I thought might be needed on my bike. So for instance you have a problem in one area you can look at 6 other .bin files and say well gee mine is way richer here than all the others so obviously I need to lean it out here, whats the leanest of them all and make a judgement about where you go with the change. So forth and so on. It's not going to be better than a few hours on the dyno but you can get it running very well indeed and at the very least try some basic stuff in areas that you have an issue. You're never going to wreck an engine by taking small steps on the mapping riding it around at road speeds unless you are silly. You will feel or even hear any issue thats a problem but always err on the side of caution. My first 2 maps were much too rich and didn't have the engine running very well, at all but once I managed to get a look at what a standard centi map looked like and then a daytona and 2 modified centi maps that had worked I had a ton of info to look at and make sensible decisions. Ciao
  7. Nice. The red really "pops" in that image and the black parts centralise everything and draw the focus to the centre of the bike and give it a shorter look. I really like the look of the pipes but I still think they are too long and not quite large enough in diameter. I've always had a hankering to make a set of those with my proportions in brushed stainless steel with TIG welds. Ciao
  8. This is not entirely correct. The closed loop function has no influence over ignition and its influence is in a steady state throttle situation only. So basically in a cruise mode where it looks at the exhaust and determines if it's rich or lean via a voltage produced by the sensor. On a Guzzi its a crude wide band sensor so all it sees is rich or lean and then switches the ecu accordingly. It is literally like a switching situation.This can lead to a slight and annoying surging feeling on some bikes and cars as well in the steady state throttle situation. It's all about emissions and turning it off which you can do through diag. I've never heard of someone disabling it and having a complaint. Ciao
  9. Have you tried turning the ignition "on" then hitting OK? Thats what the screen says to do, not hit OK and then turn the ignition "on" as you state in your post. Don't know if it matters but I follow instructions to the letter and have never had an issue. Ciao
  10. Sound like the ignition switch contacts. Ciao
  11. I have only theoretical knowledge of the PC's but I do know that anything that's an "add on" to an injection system is a last resort. I can understand how they came about and evolved but honestly once Guzzidia and Ducatidiag came along and esp if you started having running issues then that barnacle needs to go. My 1198 which is 11 years old has had from almost new a Michrotech ECU fitted which is laptop programmable and has switchable maps not to solve any running issues but because i wanted control over the engine operating system and I refused to use some crude basic add on that seemed more about profit than performance. Time to scrape off the barnacle and do it right. Ciao
  12. Personally I believe in steering dampers esp if the bike was fitted with one from new. If you've ever experienced a proper full blooded lock stop to lock stop tank slapper and lived to tell the tale then you would probably feel the same way. Ohlins are arguably the best but pricey. The std Bitubo is well about as good I guess as the std one on the bike that tried to kill me. It's better than nothing, just. I went home and ordered an Ohlins damper the next day. Ciao
  13. Sorry I couldnt load the whole image due to it's size. Ciao
  14. Ok It was just a left field thing and upon reflection probably wouldn't have an impact anyway. I think on the early models its the same style plug as i recall someone asking about it after a manual tap conversion. That and when I did the daytona engine conversion I thought I'd get rid of the fuel tap connector and cut off the level plug,doh, and had a wiring repair to do. Docc will know or Kiwi Roy. I still think the ignition switch might need to come apart. You didn't wash it before the maintenance did you or the last ride wasn't in the rain? Ciao
  15. I dont know if this counts but have you got the fuel sender and electrical fuel tap connectors around the wrong way? I THINK you might be able to connect them to the wrong things as the connectors are the same. Ciao
  16. On a 2004 cat convert model 3/4 Greenie Ciao
  17. A correction to start with, if you've had the airbox off then you will also have disconnected the ambient temp sensor mounted to the airbox as well. Wont be that unless the plug is trapped somewhere shorted out I guess. Have you thought about the ignition switch? They have a habit of creating strange issues and a disassemble and clean usually fixes them. Ciao
  18. If your bike has a lambda sensor it will have the 15rc. Thats the only practical difference between the RC and the M. Ciao
  19. Yes all good for Zink and everything else looks fine. I've always used Mobil 1 0W-40 without any issues like oiling up the filter box, it's been perfect. I am going to try a 10-60 in the Daytona engine after running in though. One issue with Diesel oils though is they are very high detergent oils and if you switch to them in an engine with a few miles on it they will break loose a lot of sludge and any build up in the engine which can lead to issues. If your engine has been kept clean you should be fine. Personally I dont see the need to run a Deisel oil in a petrol engine anymore. Anything over 1000ppm ZDDP will keep a flat tappet engine happy and around 1200-1400 is perfect. More Zink than that is getting into the diminishing returns category. There are oil manufacturers around that make flat tappet specific oils these days such as Penrite for older engines. I'll be running their full synthetic 10W-60 oil in the Daytona. Dont even think about a mineral based or fortified oil these days. Ciao
  20. Yes although the 1100 Sport uses the 16M ecu not the 15M. Same basic operating system but larger dimensionally and without the internal atmospheric pressure sensor but a remote one. Ciao
  21. I love it when people keep a bike or car for a significant percentage of their life. A tangible, physical connection to their life journey and history. I've sold so many things over time and all I have to show for it at the end of the day is some soulless cash in the bank. Very nice. Phil
  22. Dave Richardsons new book has a bit of interesting history and details on the Aero engine Chuck. He used to be the supplier of parts to the government agency that operated the drones that used them. Ciao
  23. Yes I understand. I was watching a show last night "escape from the city" which is as the title suggests people moving from the city in a tree change and Drouin was featured. I'm regularly at Lang Lang to see the in laws so not far away. Ciao
  24. Well that's using the CO trim like an axe when with Guzzidiag combined with Tunerpro you can apply a scalpel. The ability to manipulate the bin file is the key to great running and it's not hard. I'm no IT guy and even I think it's a doddle. Ciao
  25. MGS-01 Reaction rod. For those wondering about race track suitability
