Your readings "go off fast" because they are never correct the first time and here's the reason why. This is what a set of rocker arms look like at 40,000klm on a well looked after V11 sport engine. What are the chances of an accurate valve clearance check repeatability when the rocker pads look like this and the feeler gauge blade straddles this wear area when you check the clearances? You wont actually get the gap where the pad face meets the valve but some sort of average between the unworn and worn spot which will be less than where the valve stem meets the rocker pad on the wear area. So set your valves to 0.15 and end up with around 0.2-0.25 or so. Next time you do the clearances you have the gauge slightly off centre and on the worn area only and bingo a totally different reading and you scratching your head about clearances. You either need to use the feeler at the wear point or replace the rockers. It's a common issue. Pointless analysing Gauge "feel" until you've dealt with this.
Some colours respond well to photographing in certain lights and a fill in flash can make the paint "pop" as well. Silver V11 Sports always look great to me in images but not as impressive in the flesh. Not bad or anything but never as good. Thats why I don't choose car or bike colours from the computer, I always want to see it in the flesh. The only colour Supra I could see in the flesh was a red one so thats what I bought. I mean you can't really go wrong with red but I'm not choosing a car colour off a brochure or computer image. So now we have 3 red cars! When the wife says "do you want to take the Red car for a spin" I still know what car she's referring to though.
Struggling to separate the two halves of the drive shaft
Lucky Phil replied to Molly's topic in Technical Topics
Worth a try but if it's rusted together it's unlikely to work. A grease gun can only exert so much pressure, certainly less than a pair of hydraulic jacks plus my brand new shaft assy isn't totally sealed. When you slide it apart you can feel air escaping. There's a bleed hole somewhere. Phil -
Heat and working it back and forth and some penetrating oil/concoction of your choice. Two things. You need to destroy the oring in the sliding section so the penetrating oil can access the splines and the heat needs to be applied to the bevel box end of the shaft as the female end is just a shield over the splined portion. -
The reg doesn't need that much airflow as the fins and body act as a heatsink as well as cooling fins. Getting it into the airflow at your location also gets it into the road crud and rain water spray. Here's where mine is fitted and the second image is the location of the Reg on my 1198 Ducati. See the battery, below the battery is the EMU and under that is the REG, right behind the back of the oil cooler outlet and under a side fairing. Both seem to work ok. They aren't old Pommie bike charging systems. Phil
Looks brand new. good choice in mirrors. Phil
I'm thinking he wants the "original" as in the hard copy hand book owners manual, you know for "originality" May have interpreted the post wrong. Wouldn't be the first time. Phil
Wicking grade is low viscosity loctite and is designed to migrate into threads with the fastener already installed and torqued. It's also used extensively as a porosity filler when having porose castings commercially repaired. I used it to fix the porosity on my Daytona heads and did a how to thread on it. Phil
Use some loctite 638. Phil
Pull the side cover. If the post isn't loose clean the area down with solvent to flush out the oil thats migrated between the pin and the housing then apply Loctite wicking grade compound and re assemble. Phil
Personal Aircraft...
Lucky Phil replied to KINDOY2's topic in Special place for banter and conversation
There's enough muppets around that can't be trusted to operate a vehicle in 2 dimensions let alone 3. I'm the exception of course so I'd love one:). No mention of range and performance. Phil -
So for the 99-2001 bikes the distance is 3mm above the top triple and for the later Le mans and V11 Sport 2003 it's 36 mm and the Ballabio its 32mm. For the Ohlins bikes it's 30mm for the Rosso Corse and 26mm for the Cafe Sport. These are all starting points of course. The only thing to remember is if you raise the forks through the triples you need to make sure you don't run into ground clearance issues and the front guard hitting the oil cooler on full bump and that you still maintain the full 54mm fork OD dia in the lower triple clamp.
Yep. My bikes front end is basically the later long fork and top clip-on version.
The fork length varies depending on whether your bike has the clip-ons mounted above the top clamp or below. So the later bikes with the 43mm forks and top mount clip-on have forks 19mm longer in free length than the earlier swan neck clip-on bikes. The extra length is to accommodate the clip-ons above the top clamp obviously. Ohlins legs are 3mm longer again than the Marzocchi 43mm forks. So 22mm longer than the early forks. Phil
In I think 2003 a mate and his wife flew down from Sydney and stayed with us and we had stand tickets at Lukey heights. We sat there in miserable cold heavy rain and winds the only people in the stand until the MotoGP warm up was over and I said to them, we can either sit here and get soaked and cold and hope it clears or if we bail out now we can be back at my place for the start of the days racing and watch it on TV. You have come all this way, you decide I'm easy either way. They opted for the bail out. Got home an hour and a half later turned on the TV to watch the races with the island bathed in brilliant sunshine and everyone in shirt sleeves.
Anyone that rides their bike to PI deserves everything they get. I've been to PI track about 1 gazzillion times over the last 40 years and I learned in the first 2 years never take the bike. I always take the car and packed in the boot is the appropriate infostructure for everything from freezing hail and gale force winds to 40 degree heat and sunstroke and everything in between. This can happen all on the same day withing an hour, no exaduration. You can't carry enough stuff on a bike to cover off those conditions comfortably. Many times I've spectated from the car for a few hours in freezing driving rain only to be applying sun block an hour later. Phil
Rear axle build-up and dimensions of components between swing-arm
Lucky Phil replied to PeterT's topic in Technical Topics
You are correct, the calliper bracket has been reduced in width on the OB side. Here's the std width. Phil -
The carbon guards for the Ohlins forks are different mounting to the Marzocchi forks. The carbon Marzocchi front guards fit all the variations from 40-43mm dia. Phil
Measured seat hight is only one aspect of a comparative. People forget the seat width. There's a mile of difference between two identical seat heights but one is narrower than the other when it comes to getting your feet on the ground comfortably or not.
Ha, they need some post WW2 reconstruction determination. Ten years to rebuild a bridge! Sounds like us. We have determined it's going to take 40 years to build a high speed rail line between Brisbane and Melbourne. Meanwhile the Chinese are constructing 1400klm/month of HSR! I was reflecting on this a month ago as the Frecciarossa whisked us between Rome and Milano at 300kph in quiet comfort. Phil
Exactly. We just spent 4 nights at the Sheraton in Mestre. 5 min walk to a bunch of restaurants a shopping centre and the Ospedale train station and 3 stops to Venezia. It's my usual MO for foreign travel. Stay on the fringes, save a ton of money and utilise the local transit systems. I normally wouldn't stay at a Sheraton but in this case it was a very good move. Phil
