Yes docc will chime in with the parts required, he's not long done his. Ciao
Thats a lot of grief to process. Keep going, better times ahead. Ciao
- 123 replies
- 1
- v11sport
- maintenance
(and 1 more)
Tagged with:
It should be fine but i'd keep and eye on the mount bolts for tension and breakage. When you install a wedged shim like that you now introduce a bending load on the bolts when you tighten them up because the threaded bolt hole is no longer perpendicular to the mounting face. just something to keep in mind. It's not great engineering, an additional foot on the end of the stand or a slightly longer stand would be preferable. Ciao
Speed Cams in Germany
Lucky Phil replied to Bill Hagan's topic in Special place for banter and conversation
It's largely simple revenue raising under the guise of safety. We had a government policy here of cameras are only located at know dangerous locations. So then they opened a brand new 20klm stretch of freeway and put 2 sets of speed cameras 3 klms apart on a section with no obvious issues. Questions were asked about how they knew the locations were a safety issue on a brand new road that hadn't been used yet and if they were unsafe why bulild it that way? defening silence from the authorities. In the state of NSW all fixed and mobile cameras are required by law be signposted well before the camera. This includes mobile cameras used by police and contractors. They put a small mobile sign on the side of the road well before their location. Fixed cameras have a large permanent sign preceding. This is exactly right and supports the safety first approach. If you get caught by a camera in NSW you deserve it. Other states aren't so genuine. It's also pointless introducing the law as Germany is doing as you wont be able to practically police it. Ciao -
The other thing Karsten mentioned was Guzzi Germany recommended that the valve clearances be opened to .15 and .2 from .1 and .15 for similar reasons you mentioned about the cams. Although it may help the valves more than the seats as the longer the valve sits on the seat the more heat it transfers to the head so not sure how it keeps the head cooler. I must say that the opening ramps do seem quite long from my memory doing the cam timing.The exhaust lifter starts moving around 150ish degrees BBDC. You dont need to go much past TDC to get the valve clearance slightly wrong on the exhausts at least. Ciao
I'll take your word docc on it's brilliance but the cost over here is extortionate. Ciao
Here's another thing to consider John. I emailed Karsten yesterday on the Guzzi.de forum to thank him for the Centi .bin maps he sent me(2 off) and asked him how well his bike used to start from cold. I had noticed a big difference in the engine temp trim between the Centi and V11 maps esp from 0 deg to 65 deg and was interested if his bike was an "easy starter" ( my V11 with the 2 valve motor was never an "easy starter" not bad but would never start on the first crank) I just put it down to big Italian twin stuff after 35 years of cold blooded Ducatis. Anyway he said it started fine BUT he had REMOVED the std oil cooler and made a bypass unit between the oil cooler fittings because his engine used to run too cold in the rain and didn't get off the mixture enrichment part of the trim. I'd imagine Germany and Scotland would have similar climes to some degree. Just some further info to complicate things:) Ciao
You need to carry a plug repair kit, but it's nice to know there's help out there. Ciao
Thanks john and a dullard you are not. I read your wiring post on the Sfida and was impressed. The 15M is from my limited knowledge of such thing a very similar electronic architecture to the 16M but is only half the size and has the flash ability so no need to burn chips etc. You can then simply email maps to people and they can download it via Guzzidiag in literally 15 seconds to your bike. Plus you can make changes directly to the mapping on your computer and then load the file to the ecu without burning chips etc. Once I've got my map fully sorted I'll be able to provide it freely to anyone that does the same project or has a need for the same ecu mapping combination. I've got to check the cold starting first. The other thing is that the 16M would be difficult to fit dimensionally under the V11 seat. The seat base comes very close to the stuff mounted under it and It keeps all the original wiring and ecu connectors etc. Much neater. I made a special long socket to deal with the oil pressure switch by welding and machining up 2 sockets. Along was too long and a std was too short so I made one in between. There's an image here somewhere. For the head feed my crank cases were under machined so as I mentioned you couldn't get a thin walled socket on the banjo head and an Open ender also had limited throw so it ended up a little under torqued. I pulled the fuel pump off and tied back the breather hose to achieve some added room and made up an open ended ring spanner and a 3/8 drive socket with the side cut out of it. It's still hard to torque up but it's doable now in situ. I'll post some tool images. So, the special oil pressure switch socket I made from a 22mm x 1/2 inch drive and a 3/8 drive socket machined and welded together to get the correct length. The other 2 are for the head feed line off the cases banjo. Note the high quality ring spanner I sacrificed ( inherited from someone) the cutout socket was one of my old AF Proto sockets in 11/16 which as a good fit on the banjo. I have no need for AF stuff anymore as I dont work on Boeings or any aircraft for that matter so I sacrifices it instead of one of my decent metric sockets. Still hurt though doing it to a Proto. I'm leaving the Oil pressure relief for now unless I have an issue or i get bored. 60 psi max is fine and as long as the hot idle is around 10 I'm happy as well. Keep up the good work John, I'll be interested to see how the cooler turns out. Ciao
But are they "elegant"? Ciao
The gold lever blades look a little "in your face" in the images, there're not as bad in real life. Those levers are so nicely made and functional and dirt cheap on ebay. I rate them. The only improvement that could be made is that the tiny indexing ball for the span adjuster tends to rust but its a simple and cheap solution to source a few SS bearing ball from the bearing shop and replace them. Should have gone with the silver blades and adjuster. Ciao
I'm so subliminally artistic it just comes without even being aware. Ciao
So glad I got the bins in the shot docc:) Ciao
Pretty much any mirror is like a wart but you do need them on a road bike, at least until someone comes up with a decent helmet or cycle mounted rear vision LED screen. Here are mine, Rizzoma bought 8 or so years ago. As small and neat as I could find and still provide a decent rear view. Owing to my massive,broad and manly shoulders I have them extending about an inch past the bar tips but you can adjust them in further and down further if you want a more stealth look. Quality pieces. Ciao
So it's been a while since I updated this thread, but I've been doing stuff. Not "Chuck" type doing stuff but chipping away. Firstly I had a very minor oil weep to sort from the head oil feed banjo on the cases and replace the oil pressure switch where the gauge was fitted. The oil feed banjo was a real bastard to do and necessitated making 2 special tools. I hadn't really done it up tight enough due to the head being so close to one part of the cases you couldn't get a ring or socket on it and even an OE spanner had limited movement. Anyway finally sorted that and used my other special tool to re fit the oil pressure switch. The other issue was of course the fuel tap and I've covered sorting that elsewhere. Its now lovely to use and doesn't leak, hooray. I've got a new one on the way and I'll mod it as well. The biggest issue was the mapping and I spent many hours getting up to speed on Guzzidiag including reading every post on the Guzzi.de forum going back 9 years where Paul Daytona and Meinolf and Beard the Wizard behind diag along with Paul live. This is the home of Guzzidiag and there's a ton of info there. I'm amazed that Paul and Beard got the first iteration up and running in a few months, impressive. With my rudimentary understanding of the system my thoughts were to obtain a .bin file from a Centauro which has a 16M ecu and simply transfer the mapping info into the 15M. Gritman in England you may remember did the same engine swap and kindly sent me his map and I tried that. It didn't run that well and from the fuel map 3D it looked very rich. It ran better than the std V11 map but wasn't ride-able except around the block. I hadn't seen a std Centi map at this point so I had nothing to compare with. At the same time thanks to audiomick one of the mods at Guzzi.de and a fellow Aussie living in Germany I was put in touch to Karsten who also had some Centi .bin files and generously sent them to me. I now also had a couple of enhanced Centi bins to compare. All this is extremely useful if you actually want to learn and see whats safe to do. It gives you known references. I also had to buy a brand new ECU as the original looks like it had a failed baro sensor. It worked ok but I suspect it had reverted to a default baro setting. So today I loaded the new bin with the Centi mapping ( which has different load and rpm break points) into the new ecu and fired it up. A little ropey to begin with until I got the balancing and idle sorted and then took it for a ride. Straight away it worked really nicely, only complaint was very minor popping on the overrun. I tweaked the CO up a little from 0 and got that eliminated and it runs and rides like a champ. So time to put some miles on it and see whats what. Big thanks Paul, audiomick and Karsten for the assistance as well as Beard for Guzzidiag and the guys that helped it evolve into what it is today. It's a really good tool and in my case has been totally faultless to use. Ciao
I'm speechless docc you've set the bar very low there:). If you need mirrors that big you're not riding fast enough.Dead flies on the back of the helmet? Ciao
True docc but the fun police make you have them:( Ciao
- 123 replies
- 1
- v11sport
- maintenance
(and 1 more)
Tagged with:
Submit an image for ratification please docc:) Ciao
