Sounds good. Give me a time and place Phil
Arrived in Mandello today and went straight to the Guzzi museum for a look. Lots of people in town for the Guzzi weekend so lots of enthusiast stuff happening. Here's a Greenie from the museum and an image through the gates of the new factory under construction. Phil
- 38 replies
- 10
Wandering the streets of Roma and Milano you rarely see any Guzzis. Considering they build the things only 65klm's from Milano you'd think they would be commonly seen on the streets of Milano but nope. Here's a few I've spotted. The most common non scooter around the cities? The big BMW GS's in all their forms over the last 15 years or so. Hundreds of them. I've even spotted 2 old BMW K100RS's a blue and a red one both in beautiful condition the same as the new ones I toured Europe back in 84 and 86. Blue in 84 and red in 86. Guzzi's though are rare birds. Off to Mandello tomorrow. Sure to see some Guzzis there, maybe.
- 38 replies
- 11
A Guzzi Races the Isle of Man TT
Lucky Phil replied to Randy's topic in Special place for banter and conversation
Nice story. I hadn't heard of this. A little surprised that there were so many newcomers that didn't know their way around on their first escorted lap as most including the year we were there with a newcomer we did a lot of laps before the practice week even started. There was no escorted laps in those days for newcomers. Phil -
You can often drive the old bearing out with a largish flat bladed screwdriver of a 1/2 inch steel punch with a sharp edge by inserting the punch/scredriver into the axle hole from the opposite side and levering the spacer to one side to get the punch onto the inner race edge. Once one side is out the other is easy. I then grind a notch in one end of the spacer so next time the screwdriver gets onto the inner race easily. Heat the wheel hub with a heat gun and have the bearings in the freezer and they often just drop in and you can use the old bearing as a driving tool on the outer race if you need to.
There are aftermarket bushes available you need to measure the bush dimensions and order for a model thats applicable to that. Sometimes thats the only way. Phil
The valve is fine and the buildup to be expected on a 2 valve engine thats done a bit of suburban/commuter riding. Production port finish, same as just about any of the time
How to edit the engine map for a V11 15M ECU?
Lucky Phil replied to nuevototem's topic in Technical Topics
The original spacers are notorious for being too short and killing bearings before their time. Will do, first day and first gelato done. Phil -
You can acquire an old windows laptop for exactly nothing these days. Thats what I would do -
That shouldn't happen if the wheel spacer is the correct length. You should be able to crank up the axle nut even over tight and it shouldn't affect the wheel bearing lateral clearance. You should check the spacer length as it's too short. The bearing clearance is independent of the axle nut torque. That is the precise purpose of the bearing spacer. Greetings from Roma -
I don't have an image docc and the new throttle bodies on the Daytona engine don't suffer the issue. I considered bending the bracket as well but in the end I used some .028 lockwire in one wrap around the cable end Ferrell and wired back to the inboard side of the bracket. It served to pull the cable ferrell flange hard against the bracket face and keep it aligned. It also helped a tiny bit with throttle cable play as previously the ferrell flange would kick away at an angle to the bracket at zero throttle and then get pulled into alignment as you opened the throttle. If you look at yours when you open the throttle the ferrell probably gets pulled straight when you load the cable and all the wear occurs when the throttle is closed at idle or on the overrun. Thats the way it was with mine anyway. Phil
Not sure. My bike with the old engine did it with a new timing sensor, old sensor, new and older plugs and even with the timing chain replaced by gears which dispelled the theory it was timing chain slack/tensioner. Phil -
A MAP torch doesn't usually have a fine enough tip for heating the bridge screws and you need to use great care as you can easily melt the alloy bridge very thing section around the retaining screw. The yamaha seals a re also very cheap and what I used. The p/n is in the thread I'm sure. Phil
Yea I've not seen that before either docc. Phil
The throttle sleeve angle is an old issue docc. I have lockwire around the sleeve and tied to the bracket to pull the outer sheath into alignment with the bracket so the cable has a straight shot at the cam. Sounds like you have got the other damage sorted though. No need for a new cable. Even flight control cables are allowed some broken wires. Phil
I've mentioned before the ignition timing step on the std map at the low throttle angles of 4.2 and 5.1 degrees at the problematical rpm. Standard map is and 18degree ignition advance between 2200 and 2700 rpm at 4.2 degrees. Meinolfs map has cut this to around 7 degrees in the same general area although he's changed the rpm break points a little so a perfect comparison isn't available. He's also pulled some timing out at the same rpm range at 5.2 throttle angle as well so if this has reduced the issue then if it was me I'd pull a bit more out at the same ranges and see if that cures it. You can't get tuning right 100% on lambda readings alone, feel and lots of miles in varying riding conditions comes into it as well. My old engine would cough at times and then you couldn't make it if you tried. Maybe the issue is just a mechanical design issue at the end of the day if it can't be tuned out. The v11 engine may just have a small area of combustion instability under certain conditions due to the combustion chamber and piston crown design. Not sure, but if the Meinolf map has improved the issue noticeably I'd try pulling some more advance out of it at those rpm and throttle break points and see if it goes away. If not then put it back in again. Nothing to lose. Phil -
Significant changes there in every area. Phil -
Lucky Phil replied to sign216's topic in Special place for banter and conversation
They forgot the final line in the add. "The bold way to make time" in the workshop up to your arse in oil and broken engine parts"
