Thanks docc I'll check my charger when I get the bike back together. It's possible to that the old reg might have been charging ok when cold but not when hot maybe. I'll check the seat base as well,good tip. Ciao
Docc for the second time my battery has leaked. After the original one leaked I wired the headlight direct with some mini relays to bring the reference voltage into line fitted a new battery and checked the charging rate and it was fine. When I pulled the battery to fit the new engine I noticed it had started to leak again( luckily I had placed some absorbent material into the battery rubber tray) I have now fitted a new regulator I had laying around as the old one did show some signs of heat damage to the epoxy back around the wiring area. Do you think my keeping the bike on a trickle charger has caused this or my not conditioning the new battery or a faulty reg or all of the above? Ciao
I've removed seals from quite a few double sealed bearings to use in engines when I didn't have the non sealed types and always found them to be adequately greased. I mean it cant hurt to do as you suggested I suppose. Ciao
A new double sealed bearing will already be greased. Ciao
They come up for sale regularly. Ciao
I can check for you docc,I have one down in the garage. My plan was to upgrade the bike to the later tail(purely for weight savings) and the later in tank pump tank and get the whole lot painted.Problem is I cant use the later tank now with the Daytona engine as you loose too much steering lock and its reduced already. Oh and for those interested the in tank pump tanks are 20mm longer from the front mounts to the front of the tank. From the front mounts to the rear mounts is the same. So they extended the front of the tank when they went to the longer frame. I suspect if you fitted the later tank to the earlier frame you would lose some steering lock as well. Ciao
Yep that's what I'm referring too. I refer to it as a seat cowl just because its just a decorative cowl piece and really has nothing to do with the seat as such. The factory call it a "tail" or "rear fairing" depending on the model,earlier or later. This is the earlier one you're after up till 2002 by the parts manual. This is the 2002 and onwards. Ciao
At least the valves wont have any trouble exiting when the inevitable happens Ciao
The changeover for the seat cowls was 2002. So you can fit the later type post 2001 to earlier if you have the additional mount rail and the plastic rear compartment as opposed to the plastic bag arrangement. Ciao
Yes I have a later tail piece and the latch brace to fit to my Greenie one day. Its way lighter than the original. Ciao
I'm betting it wasn't a grade 8 bolt. Ciao
I feel seasoned ,that's for sure. If you want to see how to lets say mature with style check out this story on Mal Campbell ( its from 8 years ago but interesting none the less). I caught up with him as usual at the Phillip Island classic last weekend and he's still mighty fast on his RC30 Honda Superbike. I didn't get a chance to get the watch on him but from memory last year he was doing 1:41's and still looks as fast. The quickest he's ever been around PI was in the 1:36's when we did the 98 world supers. So that was 22 years ago on a faster bike, impressive. Don't want to do a disservice to Mal but he's a bit older than me and I'm 61. Love seeing the older racers still getting around quick and he looks totally safe and smooth. http://www.motorsportretro.com/2012/05/interview-mal-campbell/ Ciao
Kinda sounds like it Pete but they are usually pretty reliable aren't they? Ciao
Get rid of that clutch for starters and pull the selector plate off the gearbox and have a look at the springs. The crunching is a by product of miss selection and too much difference in the relative gear rotational speed. Bite the bullet and ditch the clutch though, the risk of an exploding flywheel is too great. Its not like when they fail you just get a bit of clutch slip,what you can get is half the engine/gearbox taken out if it lets go. Then you may as well scrap the entire bike. MG cycle sells a replacement steel single plater. Ciao
Yes they will fit. My bike has Grisso 2 valve rocker covers. As will the front timing cover gasket which I have also used on my engines both the V11 and the Daytona. Ciao
I'd really like to own a HP2. Ciao
You cant reskin Staintunes as they are an all welded SS muffler. Just buy a new one or get the dents pulled out and maybe some weld and grind and polish. Ciao
Is that a HP2 in the background of the first Image? Ciao
these are what you need. Don't waste your time with anything else. These metal core/base gaskets are light years ahead of anything else even fancy silicon gaskets thats why modern engines all use them where gaskets are required. May as well take advantage of new technology such as it is them being around for like 20 years. Ciao
I'd like one of the new mid engined Corvetts. How much is a kidney worth these days. Ciao
So I got tired of trying to find a paint match for the Greenie frame. Did a lot of research mainly historical here and on the interweb and anything that was suggested as really good wasnt available here so I went bugger it and got 500ml of 2 pack matched. My r/h pork chop was faded and polishing it didnt help so I thought now was the time to address it. The main frame isnt too bad and I need to paint the front frame support where I removed the horn and regulator bracket as well. Here's the result from an automotive paint supply places special machine. The top 10mm where my fingerprint is (doh) is the new paint. Good enough for me. I asked if he could cross reference what the machine came up with to a code or particular car model with the same shade. Unfortunately not. With the piece in your hand its only the surface finish due to my fingerprint that gives it away, the colour is as close to perfect as you'll get. BTW the guy didnt tell me about the wet area just handed it back to me with the tin of paint. Must be some old paint guys party trick:) Ciao
This ones AWD 6 speed manual with 260kw (350HP) and goes around corners like a gocart. Recaro shell seals and stiff suspension. Sunday drive car for the wife and I Ciao
Yes quite:) Ciao
